Hue Lights discussion
Fri Jun 02, 2017 10:52 am
marketability offline
Re: Hue Lights discussion
Hi
Doesn't seem to affect functionality (that I can detect) but I'm getting the following event log entries that appear to be Hue Motion Sensor related...
1 Jun 2017, 08:25:38
   Hue Lights                      received "Motion Shed Temp" sensor update to 13.9 ºC
   Script Error                    embedded script: global name 'iindigo' is not defined
     embedded script, line 2, at top level
NameError: global name 'iindigo' is not defined
Fri Jun 02, 2017 11:02 am
You have a python script somewhere with a typo:
import iindigo
should only have 1 "i" at the beginning... ;)
The script may be triggered in response to a temp change from the Hue Lights plugin.
Fri Jun 02, 2017 11:08 am
Is it definitely a user script? or could it be plugin related?
damned if I can find any of my scripts that refer to the motion sensor or have a variable "iindigo"
Fri Jun 02, 2017 11:18 am
It's definitely a script, that's what the "Script Error" means...
Fri Jun 02, 2017 11:19 am
nsheldon offline
It's definitely a script and nothing in the plugin. Hunting down scripts with errors is still a bit of a pain. I noticed there's no log entry indicating a trigger was fired so you may have disabled trigger notifications in the log for the trigger that's firing. You might need to look at all the triggers that execute on temperature change and be sure the check box is checked to show the event in the log. If that doesn't help, you might have to disable all triggers and start slowly re-enabling them until you find the trigger that's executing the script with the error.
Fri Jun 02, 2017 11:31 am
ha ha :-)
will keep hunting - thanks for the help - appreciated
Fri Jun 02, 2017 11:40 am
Does it happen every time there's a temp change logged by the Hue Lights plugin? If not, then the timing of your log snippet above was just coincidental. Otherwise, it seems quite likely that there's a trigger somewhere firing on a temp change for that device (and the logging of the trigger firing is disabled as Nathan suggests).
Fri Jun 02, 2017 12:19 pm
If I initiate a "send status request" for a hue motion temperature device I get...
2 Jun 2017, 19:16:59
   Hue Lights                      sent "Motion Shed Temp" status request
   Hue Lights Error                Error in plugin execution ExecuteAction:
  File "plugin.py", line 3922, in actionControlSensor
  File "plugin.py", line 4767, in getSensorStatus
NameError: global name 'sensorId' is not defined
   Hue Lights                      sent "Motion Porch Temp" status request
Fri Jun 02, 2017 12:53 pm
nsheldon offline
That's a bug in the plugin. I didn't encounter that in my testing and didn't see that during the beta period. But it's certainly a plugin bug. I'll look into that, but may need more detailed debug logs from you. Note, however, that that error is unrelated to the script error.
Fri Jun 02, 2017 1:00 pm
Thanks nathan - will keep hunting the script error
Fri Jun 02, 2017 1:44 pm
Make a copy of your DB file and then open the copy in a text editor (it's just an XML file). Search for "iindigo" and that should help you locate the trigger/schedule/action group that it's in.
Fri Jun 02, 2017 2:05 pm
genius!
Fri Jun 02, 2017 2:16 pm
... and it worked!
thanks a ton
Sat Jun 03, 2017 12:07 am
nsheldon offline
Version 1.6.1 Posted
  • Fixed a bug that caused an error when clicking the Send Status Request button in the Indigo UI for Hue Motion Sensor devices.
  • Added support for another Hue Ambiance bulb (model ID LTC001).
Sat Jun 03, 2017 2:29 am
Thanks Nathan
Page 49 of 103 1 ... 46, 47, 48, 49, 50, 51, 52 ... 103
