New LWA019 bulbs supported? (1100lm)
Sat Oct 23, 2021 6:22 pm
Jann offline
Hi. I just bought 4 new LWA019 bulbs... here is the json:
Can you please add it to the next release?
Jann
u '56': {
      u 'swversion': u '1.76.10',
      u 'name': u 'Light #1',
      u 'swupdate': {
         u 'state': u 'transferring',
         u 'lastinstall': u '2021-10-23T18:48:48'
      u 'productid': u 'Philips-LWA019-1-A19HDLv1',
      u 'uniqueid': u 'xx:xx:xx:xx:xx:xx:xx:xx-xx',
      u 'capabilities': {
         u 'control': {
            u 'mindimlevel': 5000,
            u 'maxlumen': 1100
         u 'streaming': {
            u 'renderer': False,
            u 'proxy': False
         u 'certified': True
      u 'productname': u 'Hue white lamp',
      u 'state': {
         u 'on': True,
         u 'reachable': False,
         u 'mode': u 'homeautomation',
         u 'bri': 254,
         u 'alert': u 'select'
      u 'manufacturername': u 'Signify Netherlands B.V.',
      u 'swconfigid': u 'E5C8A5D2',
      u 'config': {
         u 'function': u 'functional',
         u 'startup': {
            u 'configured': True,
            u 'mode': u 'safety'
         u 'direction': u 'omnidirectional',
         u 'archetype': u 'sultanbulb'
      u 'type': u 'Dimmable light',
      u 'modelid': u 'LWA019'
Sat Oct 23, 2021 6:29 pm
nsheldon offline
Re: New LWA019 bulbs supported? (1100lm)
Certainly! I'll add support in the next update.
Sat Oct 23, 2021 6:33 pm
Jann offline
Thanks so much Nathan!
ps: Did I send you the correct JSON info for the bulb?
Sat Oct 23, 2021 6:37 pm
nsheldon offline
You're welcome. And yes, that was exactly the snippet of JSON I needed. Thanks!
Sat Oct 23, 2021 6:43 pm
Jann offline
...and being a programmer I actually formatted it correctly. :D
Sat Oct 23, 2021 6:46 pm
nsheldon offline
Yes! Thank you! Hahaha
nsheldon offline
Version 1.7.59 Posted
  • Added support for a new Hue Still Ceiling light.
  • Added support for 2 new Hue color pendant lights.
  • Added support for a new Hue dimmable light.
Sat Oct 23, 2021 6:47 pm
Jann offline
Damn! You're fast! Thanks!!!!
Sat Oct 23, 2021 6:49 pm
nsheldon offline
:D You're welcome.
Sat Oct 23, 2021 7:26 pm
Jann offline
....aaaannnnnd; it works!
As If I ever doubted you! :shock:
