Hue Lights Plugin Setup and mobile app
Thu Jul 20, 2023 7:55 am
rbdubz3 offline
Is it a requirement to use the Philips Hue mobile app for pairing and setup of each bulb/sensor/etc prior to using this plugin? Or is it recommended to do all setup via the Indigo plugin?
I automate because I am lazy :D - My Plugins: https://forums.indigodomo.com/viewforum.php?f=309
Fri Jul 21, 2023 6:42 am
Re: Hue Lights Plugin Setup and mobile app
The plugin can only do things after the lights / sensors are setup in the hue or equivalent app on the phone
But after a light is setup the plugin will see the new light and will add an indigo device linked to that light
the indigo name is then
Hue_bridge#_light#_nameon huebridge
After that you can set the light from indigo.
