2022.11.24 ‘is not a dimmable device’ bug
Sat Jun 04, 2022 4:06 am
CliveS offline
Karl, I upgraded from Hue Lights 1.10.24 using API v2.0 to Hue Lights 2022.11.24 using API v3.0 and back to Hue Lights 1.10.24 using API v2.0 as the following log shows ‘is not a dimmable device’
Hue Lights 1.10.24 using API v2.0 installed
2022-06-02 18:19:08.082 Hubitat Bridge received "T Living Room Display Lights" outlet state update: "on"
2022-06-02 18:19:08.118 Z-Wave sent "Living Room Twigs" on
2022-06-02 18:19:08.134 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-02 18:19:08.177 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-02 18:19:08.287 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 100, at ramp rate:5.0 sec
2022-06-02 18:19:08.664 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 100, at ramp rate:5.0 sec
2022-06-02 18:19:08.723 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100 with RGB values 255,1,44. at ramp rate 5.0 sec.
2022-06-02 18:19:08.837 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100 with RGB values 255,1,44. at ramp rate 5.0 sec.
2022-06-02 18:19:08.916 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100, at ramp rate:5.0 sec
2022-06-02 18:19:08.964 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100, at ramp rate:5.0 sec
2022-06-02 18:19:09.161 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-02 18:19:09.203 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-02 18:19:09.284 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 60, at ramp rate:5.0 sec
2022-06-02 18:19:09.354 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 60, at ramp rate:5.0 sec
2022-06-02 18:19:13.468 Hue Lights Updated "Conservatory Table Lamp" on to 60
2022-06-02 18:19:13.485 Hue Lights Updated "Living Room Gold Lamp" on to 100
Upgrade to Hue Lights 2022.11.24 using API v3.0
2022-06-02 23:33:01.912 Application Stopping plugin Hue Lights (pid 796)
2022-06-02 23:33:03.196 Application Stopped plugin Hue Lights
2022-06-02 23:33:03.196 Application Upgrading plugin Hue Lights to newer version 2022.11.24 (previous version moved to trash)
2022-06-02 23:33:03.205 Application Loading plugin "Hue Lights 2022.11.24" using API v3.0
2022-06-02 23:33:03.212 Application Starting plugin "Hue Lights 2022.11.24" (pid 36083)
2022-06-02 23:33:04.432 Hue Lights Starting plugin initialization.
2022-06-02 23:33:04.435 Hue Lights initializing ...
2022-06-02 23:33:04.435 Hue Lights path To files: =================
2022-06-02 23:33:04.436 Hue Lights detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.nathansheldon.indigoplugin.HueLights/plugin.log
2022-06-02 23:33:04.436 Hue Lights testing logging levels, for info only:
2022-06-02 23:33:04.437 Hue Lights logger enabled for INFO ==> TEST ONLY
2022-06-02 23:33:04.437 Hue Lights Warning logger enabled for WARNING ==> TEST ONLY
2022-06-02 23:33:04.438 Hue Lights Error logger enabled for ERROR ==> TEST ONLY
2022-06-02 23:33:04.438 Hue Lights Error logger enabled for CRITICAL ==> TEST ONLY
2022-06-02 23:33:04.509 Application Started plugin "Hue Lights 2022.11.24"
2022-06-03 20:04:56.856 Hubitat Bridge sending "turn on" to "T Living Room Display Lights"
2022-06-03 20:04:56.860 Hue Lights Error setRGB "Living Room Gold Lamp" is not a dimmable device
2022-06-03 20:04:56.864 Hue Lights Error setBrightness "Living Room Gold Lamp" is not a dimmable device
2022-06-03 20:04:56.868 Hue Lights Error setRGB "Living Room Colour Lamp" is not a dimmable device
2022-06-03 20:04:56.874 Hue Lights Error setBrightness "Living Room Colour Lamp" is not a dimmable device
2022-06-03 20:04:56.879 Hue Lights Error setRGB "Conservatory Table Lamp" is not a dimmable device
2022-06-03 20:04:56.888 Hue Lights Error setBrightness "Conservatory Table Lamp" is not a dimmable device
2022-06-03 20:04:56.890 Hubitat Bridge received "T Living Room Display Lights" outlet state update: "on"
2022-06-03 20:04:57.143 Z-Wave sent "Living Room Twigs" on
Back to Hue Lights 1.10.24 using API v2.0
2022-06-03 20:19:05.882 Application Stopping plugin Hue Lights (pid 34800)
2022-06-03 20:19:07.089 Application Stopped plugin Hue Lights
2022-06-03 20:19:07.089 Application Downgrading plugin Hue Lights to older version 1.10.24 (previous version moved to trash)
2022-06-03 20:19:07.136 Application Loading plugin "Hue Lights 1.10.24" using API v2.0
2022-06-03 20:19:07.136 Warning plugin "Hue Lights 1.10.24" may not be compatible with next Indigo release without an update
2022-06-03 20:19:07.142 Application Starting plugin "Hue Lights 1.10.24" (pid 39473)
2022-06-03 20:19:08.337 Hue Lights Starting plugin initialization.
2022-06-03 20:19:08.339 Hue Lights initializing ...
2022-06-03 20:19:08.339 Hue Lights path To files: =================
2022-06-03 20:19:08.339 Hue Lights indigo /Library/Application Support/Perceptive Automation/
2022-06-03 20:19:08.339 Hue Lights installFolder /Library/Application Support/Perceptive Automation/Indigo 2022.1/
2022-06-03 20:19:08.340 Hue Lights plugin.py /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Hue Lights.indigoPlugin/Contents/Server Plugin/
2022-06-03 20:19:08.340 Hue Lights Plugin params /Library/Application Support/Perceptive Automation/Indigo 2022.1/Preferences/Plugins/com.nathansheldon.indigoplugin.HueLights/
2022-06-03 20:19:08.340 Hue Lights testing logging levels, for info only:
2022-06-03 20:19:08.340 Hue Lights logger enabled for INFO ==> TEST ONLY
2022-06-03 20:19:08.340 Hue Lights Warning logger enabled for WARNING ==> TEST ONLY
2022-06-03 20:19:08.341 Hue Lights Error logger enabled for ERROR ==> TEST ONLY
2022-06-03 20:19:08.341 Hue Lights Error logger enabled for CRITICAL ==> TEST ONLY
2022-06-03 20:19:08.341 Hue Lights check /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.nathansheldon.indigoplugin.HueLights/plugin.log <<<< for detailed logging
2022-06-03 20:19:08.341 Hue Lights Plugin short Name Hue Lights
2022-06-03 20:19:08.342 Hue Lights my PID 39473
2022-06-03 20:19:08.342 Hue Lights set params for indigo V 2022.1, indigo_API V:3.0, python V:2.7.18
2022-06-03 20:19:08.342 Hue Lights indigo_API V:3.0
2022-06-03 20:19:08.393 Application Started plugin "Hue Lights 1.10.24"
2022-06-03 20:36:33.231 Hubitat Bridge sending "turn on" to "T Living Room Display Lights"
2022-06-03 20:36:33.292 Hubitat Bridge received "T Living Room Display Lights" outlet state update: "on"
2022-06-03 20:36:33.303 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-03 20:36:33.353 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-03 20:36:33.385 Hubitat Bridge received "T Living Room Display Lights" outlet state update: "on"
2022-06-03 20:36:33.431 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 100, at ramp rate:5.0 sec
2022-06-03 20:36:33.447 Hue Lights Sent Hue Lights "Living Room Gold Lamp" on to 100, at ramp rate:5.0 sec
2022-06-03 20:36:33.469 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100 with RGB values 255,1,44. at ramp rate 5.0 sec.
2022-06-03 20:36:33.494 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100 with RGB values 255,1,44. at ramp rate 5.0 sec.
2022-06-03 20:36:33.544 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100, at ramp rate:5.0 sec
2022-06-03 20:36:33.561 Hue Lights Sent Hue Lights "Living Room Colour Lamp" on to 100, at ramp rate:5.0 sec
2022-06-03 20:36:33.684 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-03 20:36:33.703 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 50 with RGB values 128,106,42. at ramp rate 5.0 sec.
2022-06-03 20:36:33.774 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 60, at ramp rate:5.0 sec
2022-06-03 20:36:33.798 Hue Lights Sent Hue Lights "Conservatory Table Lamp" on to 60, at ramp rate:5.0 sec
2022-06-03 20:36:35.253 Hue Lights Updated "Conservatory Table Lamp" on to 60
2022-06-03 20:36:35.294 Hue Lights Updated "Living Room Colour Lamp" on to 47
2022-06-03 20:36:35.303 Hue Lights Updated "Living Room Gold Lamp" on to 100
2022-06-03 20:36:35.522 Z-Wave sent "Living Room Twigs" on
2022-06-03 20:36:35.586 Z-Wave sent "Living Room Twigs" on
2022-06-03 20:37:27.181 Hue Lights Updated "Living Room Colour Lamp" on to 100
======================= print Hue Lights =====================
== Bridge:0, ipNumber:192.168.100.240, hostId:UbtKp3qSyplU5kKWcoQaN3Vy--cAw0AuYv7Jmva8, paired:True, #of lights:15, sorted by:id
ID ONoff Reach modelId--------- type--------------------- uniqueid------------------ Name------------------------------- ProductId-------------------- manufacturername------------- ProductName------------------ Group indigoDevName-----
1 1 0 LWB006 Dimmable light 00:17:88:01:10:59:65:e0-0b Conservatory Light Signify Netherlands B.V. Hue white lamp 4 Conservatory Light
2 0 0 LWB006 Dimmable light 00:17:88:01:10:3a:3b:c5-0b Hall 1 Ceiling Light Signify Netherlands B.V. Hue white lamp 5 Hall Ceiling Light 1
4 1 0 LWB006 Dimmable light 00:17:88:01:10:4c:53:d4-0b Hall Coat Cupboard Light Signify Netherlands B.V. Hue white lamp 5 Hall Coat Cupboard Light
11 0 0 LWB006 Dimmable light 00:17:88:01:10:3a:28:10-0b Hall 2 Ceiling Light Signify Netherlands B.V. Hue white lamp 5 Hall Ceiling Light 2
12 0 0 LWB006 Dimmable light 00:17:88:01:10:59:63:5c-0b Bedroom 1 Ceiling Light Signify Netherlands B.V. Hue white lamp 11 .Bedroom 1 Hue Ceiling Light
13 1 0 LTW012 Color temperature light 00:17:88:01:02:63:21:5a-0b Jane Lamp Philips-LTW012-1-E14CTv1 Signify Netherlands B.V. Hue ambiance candle 11 Bedroom 1 Bedside Light Jane
17 1 0 LCT015 Extended color light 00:17:88:01:03:fa:62:72-0b Front Door Light Philips-LCT015-1-A19ECLv5 Signify Netherlands B.V. Hue color lamp 16 Drive Entrance Light
19 1 0 LCT015 Extended color light 00:17:88:01:03:86:46:51-0b Drive Garage Light Philips-LCT015-1-A19ECLv5 Signify Netherlands B.V. Hue color lamp 16 Drive Garage Light
23 1 0 LTW012 Color temperature light 00:17:88:01:02:1d:1b:e1-0b Clive Lamp Philips-LTW012-1-E14CTv1 Signify Netherlands B.V. Hue ambiance candle 11 Bedroom 1 Bedside Light Clive
24 1 0 LCT003 Extended color light 00:17:88:01:02:b8:ad:9c-0b Living Room Gold Lamp Signify Netherlands B.V. Hue color spot 9 Living Room Gold Lamp
26 0 0 LWB010 Dimmable light 00:17:88:01:02:6c:5e:26-0b Hall Porch Ceiling Light Philips-LWB010-1-A19DLv3 Signify Netherlands B.V. Hue white lamp 5 Hall Porch Ceiling Light
28 1 0 LWB010 Dimmable light 00:17:88:01:02:6c:a3:0c-0b Back Door Light Philips-LWB010-1-A19DLv3 Signify Netherlands B.V. Hue white lamp 14 Back Door Light
30 1 0 LCA001 Extended color light 00:17:88:01:06:1f:f8:fe-0b Living Room Colour Lamp Philips-LCA001-5-A19ECLv6 Signify Netherlands B.V. Hue color lamp 9 Living Room Colour Lamp
34 0 0 LCA001 Extended color light 00:17:88:01:06:1f:f8:f8-0b Bedroom 3 Light Philips-LCA001-5-A19ECLv6 Signify Netherlands B.V. Hue color lamp 13 Bedroom 2 Light Bulb
35 1 0 LCT010 Extended color light 00:17:88:01:02:73:5c:90-0b Conservatory Table Lamp Philips-LCT010-1-A19ECLv4 Signify Netherlands B.V. Hue color lamp 4 Conservatory Table Lamp
CliveS
Sat Jun 04, 2022 9:39 am
mwoodage offline
Re: 2022.11.24 ‘is not a dimmable device’ bug
I'm having the same issue :)
Hue Lights Error setBrightness "Downstairs Toilet Light" is not a dimmable device
Hue Lights Error setXYY "Downstairs Toilet Light" is not a dimmable device
Sat Jun 04, 2022 10:53 am
should be fixed in v 2022.11.26 just posted
I have changed more things to be table driven, that will allow in the future to add new features into tables and not hardcode things. those IFs had become very complex
the bug was a missing "not" in if not dimmable
and the config menu should look much better now, and i hope much easier to understand, with color, selection boxes, popup windows that show success/ failure of pairing, change ip, delete ...
see https://forums.indigodomo.com/posting.php?mode=edit&f=367&t=26184&p=211154
I will be out of town starting tomorrow 9 am Saturday morning CET for 2 weeks
I can fix bugs until then
Sat Jun 04, 2022 11:23 am
CliveS offline
That has fixed it, thanks and have a well earned holiday !
CliveS
Sat Jun 04, 2022 1:33 pm
I guess that was just in time delivery.
Can go to our family event. First time for 3 years everyone is getting back together.
Karl.
