2022.1.1 and 2022.11.24
Fri Jun 03, 2022 7:46 am
marketability offline
Hi
I've just upgraded to the above and am getting large numbers of repetitions of
   Hue Lights Error                'key brightnessLevel not found in dict'  line#,Module,Statement:(6365, 'parseOneHueLightData', "if device.states['brightnessLevel'] != 0:")
I am also having a second more problematic challenge - I have 3 Hue Hubs and they look to be setup correctly in the plugin config but when I try and select a Hub when configuring a "Recall Hue Scene" action - none of the hubs appear in the "Hue Bridge Number" drop down
Any suggestions?
TIA
Fri Jun 03, 2022 8:18 am
Re: 2022.1.1 and 2022.11.24
A bit more information from log...
 Started plugin "Hue Lights 2022.11.24"
   Hue Lights                      debug areas:[]
   Hue Lights                      bridge lights groups scenes users resources rules schedules sensors hostIds / user names ------------------- ip Numbers ---- BridgeIds-------
   Hue Lights Warning              #0    ; ipNumber:172.16.21.106 --- not properly setup
   Hue Lights                      #2         19      7     10   110         5    68         4      15 qtVoC4NsgpUpaDhj1x5dcAQ8OvV7VvZy0eDA6ULV 172.16.21.133   001788FFFE2B4481
   Hue Lights                      #3         25     12     19    83        12   125         3      35 ITLh5RAD9PNqvxP-1QL6CzRjzCaOTW7xZ6lDguyg 172.16.21.92    001788FFFE21762D
   Hue Lights Error                '1',  line#,Module,Statement:(814, 'validateRGBWhiteOnOffetc', 'elif \'groupId\'\t\tin newProps:\t\t\t\t\t\tnewProps[\'address\'] \t\t\t\t\t\t\t= u"{} (Gid:{}-{})".format(self.ipAddresses[newProps[\'hubNumber\']], newProps[\'hubNumber\'], newProps[\'groupId\'])')
   Hue Lights Error                '1',  line#,Module,Statement:(813, 'validateRGBWhiteOnOffetc', 'if   \'bulbId\'\t\tin newProps:\t\t\t\t\t\tnewProps[\'address\'] \t\t\t\t\t\t\t= u"{} (Lid:{}-{})".format(self.ipAddresses[newProps[\'hubNumber\']], newProps[\'hubNumber\'], newProps[\'bulbId\'])')
   Hue Lights Error                '1',  line#,Module,Statement:(815, 'validateRGBWhiteOnOffetc', 'elif \'sensorId\'\t\tin newProps:\t\t\t\t\t\tnewProps[\'address\'] \t\t\t\t\t\t\t= u"{} (Sid:{}-{})".format(self.ipAddresses[newProps[\'hubNumber\']], newProps[\'hubNumber\'], newProps[\'sensorId\'])')
Fri Jun 03, 2022 10:43 am
lets take one at a time:
---Lights Warning #0 ; ipNumber:172.16.21.106 --- not properly setup:
means it does not read the bridge properly. maybe relink (all) bridges
could you do a menu / print ... lights and config bridges overview. and post?
I am busy until 8:30 CET , then I will look at it further
Fri Jun 03, 2022 12:50 pm
to clarify:
the devices are assigned to a certain bridge #
if that bridge is not defined or now has a different bridge#, it will not work and will throw all kinds of errors
please check bridge and setup them up as before.
important is the bridge# and ipNumber must be the correct pair
I have no clue how that got mixed up.
Fri Jun 03, 2022 12:59 pm
Thanks Karl - I’ll have a crack at that
Fri Jun 03, 2022 1:27 pm
Bridge configuration and selection needs lots of work IMO. It's too confusing and too easily broken.
Fri Jun 03, 2022 2:51 pm
I agree, but changing bridge# to a device will require to rewrite large parts of the code.
I will have time in 2 weeks when I am back home - leaving on sunday for Italy with family
Sat Jun 04, 2022 12:58 am
Hi
The challenge I have is that the plugin automatically detects the three bridges but places them in a different slot to the previous versions
i.e. the bridge with IP xxx.xxx.xxx.92 was "0" but is now slot "3"
I've tried using "add", "edit" to override the "default" bridge but that doesn't seem to work for me
If I use one of the manual slots to connect one of the bridges - it looks like it works but I can't edit a hue device to the new slot
Sorry for the hassle
Do I have any options to downgrade temporarily? - Unfortunately I've upgraded the OS to Monterey 12.4
Sat Jun 04, 2022 12:59 am
PS @Karl... Have a great holiday!
