HomeKitLink shuts down after power cut
Posted: Wed Aug 16, 2023 3:32 am
Glenn, I am having problems with short power outages and slowly working out a way to restart all plugins that fail to restart properly due to lack of internal and external IP’s.
The HomeKitLink plugin is one that I cannot restart as it crashes when loading and I end up with a red spot instead of green which means that it will not respond to a reload request and has to be manually started.
Is there a way to restart the plugin after a set time instead of just closing it?
- Code: Select all
2023-08-15 13:48:57.686 Application Loading plugin "HomeKitLink Siri 0.6.16" using API v3.2
2023-08-15 13:48:57.690 Application Starting plugin "HomeKitLink Siri 0.6.16" (pid 685)
2023-08-15 13:48:58.698 HomeKitLink Siri Error Error in plugin execution InitializeMain:
File "plugin.py", line 61, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/HomeKitDevices.py", line 34, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/HKConstants.py", line 63, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/util.py", line 63, in get_local_address
type: local variable 'addr' referenced before assignment
- Code: Select all
HomeKitLink Siri
HomeKitLink Siri ================================================ Initializing New Plugin Session =================================================
HomeKitLink Siri Plugin name: HomeKitLink Siri
HomeKitLink Siri Plugin version: 0.6.16
HomeKitLink Siri Plugin ID: com.GlennNZ.indigoplugin.HomeKitLink-Siri
HomeKitLink Siri Indigo version: 2022.2.2
HomeKitLink Siri Python version: 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
HomeKitLink Siri Python Directory: /Library/Frameworks/Python.framework/Versions/3.10
HomeKitLink Siri
HomeKitLink Siri ================================================== End Initializing New Plugin ==================================================
