HomeKitLink Pre-release 0.6.27
Mon Jun 12, 2023 9:21 pm
GlennNZ offline
Pre-release version for testing for 0.6.15
https://github.com/Ghawken/HomeKitLink-Siri/releases
Changelog
Version 0.6.15
Changes
Two big ticket library based items:
1.. Improved support for multiple advertising of IPs, and support for Ivp6 networks
Homekit Server Options: Advertised Interfaces: (in my example)
::1 = (IVP6 localhost)
192.168.1.6 = (Ethernet interface)
192.168.1.92 = (Wifi interface)
Homekit Server: IP address
IVP4 IP interface that server is running on
If you change options in advanced options - reload plugin to action.
&& if delete all content from boxes and reload will return to default behaviour.
2. Use byte/binary data for UUID
This is the UUID for the bridge which is generated when pairing. Some library users have reporting issues with newer versions of OS returning to lowercase, uppercase etc.
Use byte/binary data for UUIDs as it appears apple changing from Lowercase to Uppercase at times. This bypasses this issue now and into the future.
These are only created on device pairing, so if believe have an issue related to this. Delete bridge in HomeKit App. Then reset bridge with menu item in HKLS Plugin. Then repair the bridge.
Thu Jun 15, 2023 11:46 pm
GlennNZ offline
Re: HomeKitLink Pre-release 0.6.15
Pre-Release 0.6.16
Replaces
Fix for a code merge issue in state.py
Glenn
Sun Sep 03, 2023 1:18 am
GlennNZ offline
Pre-Release 0.6.26
Update for sluggish notifications for multiple bridges.
Removes combined Zeroconf instance and creates new one for each bridge.
Appears to have returned to instantous feedback.
Hopefully have reworked all the advanced server options, IvPVersion, advertised IPs etc. into to this reworked code. Please report back if any issues.
Glenn
Mon Sep 04, 2023 10:23 am
7rdr7 offline
Nice update! Much quicker notifications.
Fri Oct 06, 2023 8:44 pm
GlennNZ offline
Re: HomeKitLink Pre-release 0.6.27
0.6.27
Incorporates previous pre-release updates/fixes for speed of notification
& Adds
Library Updates:
Fix for Multiple List Pairings
This should fix pairing with iOS 17 as well as secondary users not being able to use the bridge for iOS 17 and older.
(Fixes issues with invited accounts not being able to access devices)
Save Pairing Bytes when received. (fix for older bridges paired before we saved raw byte UUID)
Fix for rare OS17 devices loosing contact with bridge after upgrade
Ensure tasks are not garbage collected before finish
Add Support for "wr" Write Response functions
Enables future support for NFC Lock/Key Homekit devices, which may look into...
Sat Oct 07, 2023 1:57 am
Oooh so would that NFC functionality potentially allow us to enable the Homekey functionality?
Sat Oct 07, 2023 2:01 am
GlennNZ offline
Yep - have a version testing now - everything in it is basically blank - but when enabled the NFC services/characteristics to Lock - Get a nice new function added to your lock - setup and then it appears I have a HomeKey in my wallet for home!
Need a NFC reader to use it …. (which don’t have currently - ordered though…)
Not quite sure how would then add functionality into Indigo anyway….
HomeKey - Wallet app presumably creates a NFC which then a reader needs to read to set rest in motion.
Sat Oct 07, 2023 2:11 am
That would be amazing. What NFC reader did you order?
Sat Oct 07, 2023 2:20 am
GlennNZ offline
I ordered the ESP based Adonno
https://adonno.com/tagreader/
Needed stand-alone really if going to mount it outside eventually..
It uses ESPHome which is HA based - so may need a bit of work to get working probably, and may need its own plugin …
Although pretty sure there is a ESPHome to MQTT option - where everything is send via MQTT.
Also seems to be a couple of months of delay potentially shipping…
Benefit is : Could mount it externally and use as door lock/unlock ideally, with/without home key…
Sat Oct 07, 2023 2:58 am
Interesting. I shall await your results with bated breath!
I actually ran an extra cat6 cable to my front door for exactly this kind of thing, so hopefully could get it to work with that.
Sat Oct 07, 2023 3:07 am
GlennNZ offline
The POE converters which can buy from AliExpress are great for this sort of thing.
POE —> micro-USB, or POE to Camera 12V, sure there will be POE —>USB-C
https://a.aliexpress.com/_mOh7yse
Can use the Cat for Power via POE and one of these converters and then wifi for connection.
The other benefit of POE is because high voltage you don’t get the voltage drop you see if try to run power cables from far away source.
Sat Oct 07, 2023 3:09 am
Oh indeed! I run a lot of things in my house via PoE adapters from my unifi switch. Also makes it a lot easier to reboot them if something goes wrong!
Sat Oct 07, 2023 3:14 am
GlennNZ offline
The other benefit I have found with them if have a lightning strike - these adapters get fried rather than the switch or the device…
Sat Oct 07, 2023 6:29 am
Not a major issue in my area, but yeah.. lots of little benefits!
Sat Oct 07, 2023 6:31 am
I’m curious.. would it also be possible to expand this to work with the work pass functionality?
