Late to the party: Need help converting plugin to PY3
Sun Oct 22, 2023 5:35 pm
BillC offline
Several years ago with much help from Jay, I adapted an old version of the NOAA weather plugin to read an XML file. The file is generated and posted to a local network site by a hardware device called "Web Energy Logger (WEL)) that converts one-wire sensor HVAC data and updates the file periodically. The plugin worked fine until (of course) I updated Indigo to 2023.1.
I have attempted to convert the code to PY3. The plugin runs, I can create a device in Indigo, and the device states from the plugin's devices.xml file are shown in the main Indigo window. However, no data is updated.
I have inserted debug log points to see what modules are being called, and the only ones that are logged are "Startup" and "Concurrent Thread." Notably, the self.deviceStartComm and self.Update routines do not execute. I have tried to force self.deviceStartComm in startup(self) without success.
Also, in the indigo window, the device's "Comm Enabled" block is not checked even though "Enable Indigo Communication" is selected in the device edit window.
I've obviously overlooked something simple, but have been pounding on this for a couple of days with no real progress. Any help would be much appreciated.
plugin.py:
# Imports
import urllib.request, urllib.error, urllib.parse
import logging
from xml.dom.minidom import parseString
# Globals
theUrl = "http://10.1.0.30:5150/data.xml"
fields = {"dataDate":'Date',"dataTime":'Time',"TEST":'test',"propHeat":'PropHeating',"outdoorTemp":'OutdoorT',"stage2":'HP_ComprHi',"cooling":'HP_Cool1S',"heating":'HP_Heat1S',"defrost":'HP_Defrost',"vaporTemp":'HP_VaporT',"liquidTemp":'HP_LiquidT',"supplyTemp":'HP_SupplyT',"downstairsReturnTemp":'HP_ReturnDnT',"upstairsReturnTemp":'HP_ReturnUpT',"hotWaterTemp":'Water_Hot',"coldWaterTemp":'Water_Cold',"returnDeltaT":'AirRetDeltaT'}
   # Class properties
   def __init__(self, plugin_id, plugin_display_name, plugin_version, plugin_prefs):
#      """ Standard Plugin Initialization Method """
      super().__init__(plugin_id, plugin_display_name, plugin_version, plugin_prefs)
      self.plugin_file_handler.setFormatter(logging.Formatter(log_format, datefmt='%Y-%m-%d %H:%M:%S'))
      self.debug = plugin_prefs.get("showDebugInfo", False)
      self.device_list = []
   def __del__(self):
   def deviceStartComm(self, device):
      self.logger.debug(u"deviceStartComm called")
         self.logger.debug(u"Starting device: {device.name}")
         if device.id not in self.device_list:
            self.update(device)
            self.device_list.append(device.id)
      except requests.exceptions.ConnectionError:
         self.logger.warning(u"Unable to connect to Indigo WEL device.")
   def deviceStopComm(self, device):
      self.logger.debug(u"Stopping device: " + device.name)
      if device.id in self.device_list:
         self.device_list.remove(device.id)
   def startup(self):
      self.logger.debug(u"Startup called")
      for device_id in self.device_list:
         self.deviceStartComm(self, indigo.devices[device.id])
      self.logger.debug(u"Starting concurrent thread")
      self.sleep(10)
         while True:
            self.sleep(10)
#            self.logger.debug(u"Line 71")
               # call the update method with the device instance
               self.logger.debug(u"Calling self update for: {device.name}")
               self.update(indigo.devices[device_id], force_update=True)
      except self.StopThread:
         self.logger.debug(u"Exception stopped thread")
         pass
   def update(self,device):
      self.logger.debug(u"Updating device: " + device.name)
      # download the file
         f = urllib.request.urlopen(theUrl)
      except urllib.error.HTTPError as e:
         self.logger.error(u"Error getting data: %s" % (device.pluginProps["address"], str(e)))
         return
      theXml = f.read()
      theDocTree = parseString(theXml)
      for node in theDocTree.getElementsByTagName("Device"):
         for state,fieldName in list(fields.items()):
            name = node.getAttribute("Name")
            value = node.getAttribute("Value")
            if name == fieldName:
               newValue = value
               if (fieldName == "OutdoorT")|(fieldName=="HP_VaporT")|(fieldName=="HP_LiquidT")|(fieldName=="HP_SupplyT")|(fieldName=="HP_ReturnDnT")|(fieldName=="HP_ReturnUpT")|(fieldName=="Water_Hot")|(fieldName=="Water_Cold")|(fieldName=="AirRetDeltaT"):
                  newValue = str(round(float(value),1))
               if value == "0.000000":
                  newValue = "0"
               if value == "1.000000":
                  newValue = "1"
               self.updateDeviceState(device, state, newValue)
   def updateDeviceState(self,device,state,newValue):
      if state not in device.states:
         device.stateListOrDisplayStateIdChanged()
      if (newValue != device.states[state]):
         device.updateStateOnServer(key=state, value=newValue)
Devices.xml:
<?xml version="1.0"?>
<Devices>
   <!-- Define some devices -->
   <Device type="custom" id="welData">
      <Name>WEL Data</Name>
      <ConfigUI>
      </ConfigUI>
      <States>
         <State id="dataDate">
            <ValueType>String</ValueType>
            <TriggerLabel>Data Date</TriggerLabel>
            <ControlPageLabel>Data Date</ControlPageLabel>
         </State>
         <State id="dataTime">
            <TriggerLabel>Data Time</TriggerLabel>
            <ControlPageLabel>Data Time</ControlPageLabel>
         </State>
         <State id="heating">
            <ValueType>Boolean</ValueType>
            <TriggerLabel>Heat</TriggerLabel>
            <ControlPageLabel>Heat</ControlPageLabel>
         </State>
         <State id="cooling">
            <TriggerLabel>Cool</TriggerLabel>
            <ControlPageLabel>Cool</ControlPageLabel>
         </State>
         <State id="defrost">
            <TriggerLabel>Defrost</TriggerLabel>
            <ControlPageLabel>Defrost</ControlPageLabel>
         </State>
         <State id="stage2">
            <TriggerLabel>Second Stage H/C</TriggerLabel>
            <ControlPageLabel>Second Stage H/C</ControlPageLabel>
         </State>
         <State id="propHeat">
            <TriggerLabel>Propane Heat is On</TriggerLabel>
            <ControlPageLabel>Propane Heating</ControlPageLabel>
         </State>
         <State id="vaporTemp">
            <ValueType>Number</ValueType>
            <TriggerLabel>Heat Pump Vapor Temp °F</TriggerLabel>
            <ControlPageLabel>Heat Pump Vapor Temp °F</ControlPageLabel>
         </State>
         <State id="liquidTemp">
            <TriggerLabel>Heat Pump Liquid Temp °F</TriggerLabel>
            <ControlPageLabel>Heat Pump Liquid Temp °F</ControlPageLabel>
         </State>
         <State id="outdoorTemp">
            <TriggerLabel>Outdoor Temp °F</TriggerLabel>
            <ControlPageLabel>Outdoor Temp °F</ControlPageLabel>
         </State>
         <State id="supplyTemp">
            <TriggerLabel>Supply Temp °F</TriggerLabel>
            <ControlPageLabel>Supply Temp °F</ControlPageLabel>
         </State>
         <State id="upstairsReturnTemp">
            <TriggerLabel>Upstairs Return Temp °F</TriggerLabel>
            <ControlPageLabel>Upstairs Return Temp °F</ControlPageLabel>
         </State>
         <State id="downstairsReturnTemp">
            <TriggerLabel>Downstairs Return Temp °F</TriggerLabel>
            <ControlPageLabel>Downstairs Return Temp °F</ControlPageLabel>
         </State>
         <State id="hotWaterTemp">
            <TriggerLabel>Hot Water Temp °F</TriggerLabel>
            <ControlPageLabel>Hot Water Temp °F</ControlPageLabel>
         </State>
         <State id="returnDeltaT">
            <TriggerLabel>Return Temp Difference °F</TriggerLabel>
            <ControlPageLabel>Return Temp Difference °F</ControlPageLabel>
         </State>
         <State id="coldWaterTemp">
            <TriggerLabel>Cold Water Temp °F</TriggerLabel>
            <ControlPageLabel>Cold Water Temp °F</ControlPageLabel>
         </State>
      </States>
   </Device>
</Devices>
Log of plugin running (no other entries):
   Started plugin "WEL Data New 1.0.1"
   WEL Data New Debug              Startup called
   WEL Data New Debug              Starting concurrent thread
Sun Oct 22, 2023 6:59 pm
Re: Late to the party: Need help converting plugin to PY3
In the "General Settings" dialog, "Plugins" tab, enable the "Enable Debug Menus" option, Then use the "Reload in Interactive Shell" menu item, which will open a Terminal window. Post what you're getting there.
Sun Oct 22, 2023 7:00 pm
Also, go through all the code and remove the 'u' from the strings (u"string value").
Sun Oct 22, 2023 7:15 pm
BillC offline
Sorry, didn’t mean to do that as pm.
I see that menu item for some, but not all, plugins; it’s not there for the one of interest. Do I need to do something in the code to enabl it?
Sun Oct 22, 2023 7:17 pm
That's strange. It's in all of mine.
Did you update the Info.plist to the correct ServerApiVersion? Should be 3.0.
Sun Oct 22, 2023 7:24 pm
BillC offline
Yes.
It’s also not available in the NOAA weather plugin. I’ll look at some of the other info.plist files and see if I can spot anything.
Sun Oct 22, 2023 7:25 pm
You are running the client on the Indigo server machine, right?
Sun Oct 22, 2023 7:51 pm
BillC offline
Can’t determine how to activate that menu item. It’s not available for the following plugins I have installed:
NOAA weather
Airfoil Pro
Email+
Timers and pesters
Sun Oct 22, 2023 7:52 pm
BillC offline
Yes.
Sun Oct 22, 2023 7:54 pm
But it is present for other plugins?
Sun Oct 22, 2023 7:58 pm
BillC offline
Some but not all. NOT for:
NOAA weather
Airfoil Pro
Email+
Timers and pesters
Sun Oct 22, 2023 7:59 pm
I have no clue. Maybe Matt or Jay have an idea about that.
Sun Oct 22, 2023 8:01 pm
BillC offline
Thanks for your help, Joe. Calling it a night, will try again tomorrow. Appreciate your assistance.
Sun Oct 22, 2023 11:48 pm
GlennNZ offline
Can I put in a plug for the excellent GhostXML plugin?
Essentially appears to be designed for this purpose - although now does a lot more.
https://www.indigodomo.com/pluginstore/38/
Should take your xml url directly and generate all device states that it can get from the xml.
Glenn
Mon Oct 23, 2023 3:19 am
NOAA weather
[snip]
Just to be sure that everyone is on the same page:
1. Indigo General Settings --> General Settings... --> Plugins --> Enable debugging menus {is checked]
2. Plugins --> NOAA Weather --> Reload in Interactive Shell
The option in number 2 is not present? That's really weird.
Screenshot 2023-10-23 at 4.12.14 AM-2.png (133.92 KiB) Viewed 1950 times
