- Code: Select all
Python 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
Connected to Indigo Server v2022.1.0, api v3.0 (localhost:1176)
But, if I ssh in to that machine I get a py2 one.
- Code: Select all
Password:
Python 2.7.18 (v2.7.18:8d21aa21f2, Apr 19 2020, 20:48:48)
[GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.57)]
Connected to Indigo Server v2022.1.0, api v2.5 (DEPRECATED) (localhost:1176)
Similarly, if I open up a terminal window manually on the remote machine (using remote desktop) that command also opens a py2 one
- Code: Select all
~ /Library/Application\ Support/Perceptive\ Automation/Indigo\ 2022.1/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost -i
I assume this is because the system default python is still 2 for me.
I do have python3 available through that command name
- Code: Select all
/Library/Application Support/Perceptive Automation which python
/usr/local/bin/python
/Library/Application Support/Perceptive Automation which python3
/Library/Frameworks/Python.framework/Versions/3.10/bin/python3
/Library/Application Support/Perceptive Automation python --version
Python 2.7.18
/Library/Application Support/Perceptive Automation python3 --version
Python 3.10.2
So how would I go about getting the INdigoPluginHost to use that version?
