Python error in reflector check code after update to 2022.1
Sat May 14, 2022 5:12 pm
DVDDave offline
My update to 2022.1 (while still on OS 12.2) has mostly gone fine after slogging through some python errors. However, I can't seem to solve an error in a reflector check script that Matt helped me with a while ago. Here is the code:
import urllib
query_url = 'http://YOUR_REFLEDCTOR_NAME_HERE.indigodomo.net/prismstatus'
   result = urllib.urlopen(query_url, None)
   if result is not None:
      server_reply_str = result.read()
      if server_reply_str == 'connected':
         pass
         # Comment out or delete this next log line after verifying it is working:
         indigo.server.log('reflector test returned connected')
         indigo.server.log('reflector test returned ' + server_reply_str, isError=True)
      indigo.server.log('reflector test returned None', isError=True)
except IOError, e:
   indigo.server.log('reflector test error: ' + str(e), isError=True)
I get this error when executing it:
   Action Group                    Reflector Check
   Script Error                    action group "Reflector Check" script error in file Reflector_Check.py:
   Script Error                    multiple exception types must be parenthesized
   Script Error                    around line 24 - "except IOError, e:"
Googling around, it looks like it has something to do with using a python2 library (comtypes) with python3 but I can't find a definitive solution. Any suggestions?
--Dave
Sat May 14, 2022 6:02 pm
Re: Python error in reflector check code after update to 202
Change this line:
except IOError, e:
to this:
except IOError as e:
Sat May 14, 2022 8:15 pm
DVDDave offline
Thanks, Dave!
FYI, I also needed to change urllib to urllib.request.
Sat May 14, 2022 8:41 pm
Cool, glad you figured it out. I zeroed in on the exception. :)
Sun May 15, 2022 10:53 am
[MODERATOR NOTE]: moved to the Python 3 conversion forum.
