BeautifulSoup "No Module Named bs4" 2022.1.2
Wed Jan 11, 2023 3:15 pm
outsidenwnc offline
I have loaded the module bs4 manually per the docs using ' pip3 install bs4 '
But get this error when Indigo starts or I reload the plugin
Ambient Weather Error Error in plugin execution InitializeMain:
File "plugin.py", line 15, in <module>
ImportError: No module named bs4
Restarted Indigo server, rebooted Mac mini and still get the error -
I have checked that the module is present using pip3 show bs4 and pip3 show beautifulsoup4 and looks correct.
I can launch the plugin scripting shell and load the module and use it. (details in image below)
See images.
I was using this plugin in Indigo 2021 successfully by manually loading the module similar method.
What am I missing???
Header from my plugin.py file
# Imports
import indigo
except ImportError:
pass
import urllib
from bs4 import BeautifulSoup
import lxml
Screen Shot 2023-01-11 at 2.37.31 PM.png (66.31 KiB) Viewed 1160 times
Screen Shot 2023-01-11 at 2.08.53 PM.png (74.16 KiB) Viewed 1160 times
Wed Jan 11, 2023 4:06 pm
outsidenwnc offline
Re: BeautifulSoup "No Module Named bs4" 2022.1.2
I found the issue.
I had not updated the ServerAPIVersion in the info.plist to 3.0.0.
Moving forward..
