Installation Problem
Thu Jan 06, 2022 1:10 pm
cjp767 offline
Clearly I've missed something. I installed the geopy library successfully, but the Life360 plugin did not install properly and gave this error in the log:
Mac Pro 5,1 (cheese grater) with Mac OS 10.14.6 and Indigo 2021.2
Starting plugin "Life360 0.2.2" (pid 72413)
Life360 Error Error in plugin execution InitializeMain:
File "plugin.py", line 42, in __init__
KeyError: key authorizationtoken not found in dict
Can you offer any guidance? It's obviously my issue. Always is.
Sun Jan 09, 2022 8:52 am
Re: Installation Problem
I don't use the plugin, so I'm shooting in the dark here.... There's every chance that the plugin installed correctly. The error message is being thrown right as the plugin is spooling up and it looks like it's expecting a token of some kind -- probably for authentication or at least identification.
If the plugin has a configuration menu, is there a field for entering an authentication token? Alternatively, does the plugin use virtual devices where the token might be entered into a settings dialog for an individual device?
Sun Jan 09, 2022 9:15 am
cjp767 offline
Thank you for the guidance--- anything could help! Unfortunately, I was not thorough in my copy/paste from the log. Here's the full sequence:
Starting plugin "Life360 0.2.2" (pid 41713)
Stopping plugin "Life360 0.2.2" (pid 41713)
Stopped plugin "Life360 0.2.2"
Note that it says "Stopped plugin"---- that means it's dead. The plugin is not running, so no configuration menu, no virtual device or anything, because the plugin did not start fully. Again, the issue is probably my own. I often miss something quite subtle. Thank you again!
Sun Jan 09, 2022 9:35 am
If you haven't already, I would recommend trying to reinstall the plugin. If that doesn't work, you might need to completely uninstall the plugin before reinstalling it.
To completely uninstall,
  • stop the Indigo server,
  • delete the plugin file (it may be in the plugins folder or the disabled plugins folder).
  • delete the plugin's preferences file which should be located in the "/Library/Application Support/Perceptive Automation/Indigo XXXXX/Preferences/Plugins/" folder.
  • start the Indigo server and wait for it to fully spool up.
  • reinstall the plugin.
Sun Jan 09, 2022 11:56 am
cjp767 offline
Thank you for that advice--- (Great idea, btw). I upgraded Indigo to 2021.2 and unfortunately I had the same result
Sun Jan 09, 2022 12:16 pm
I'm afraid I'm out of ideas. Hopefully, Ryan will spot this thread soon and get you sorted. You might try sending him a DM if you haven't already.
Good luck!
Thu Jan 13, 2022 11:40 am
ryanbuckner offline
I included the geopy library in the plugin package itself so it's no longer a requirement to install separately. I wonder if that's causing the problem.
Can you try to uninstall geopy and reinstall the plugin?
Thu Jan 13, 2022 11:41 am
ryanbuckner offline
By the way I think you're the first ever user of this plugin (besides myself) so I appreciate the note
Thu Jan 13, 2022 11:46 am
ryanbuckner offline
So this error is being raised when trying to pull the authorization token from the plugin config. Are you getting this error before you're able to configure the plugin with username, password, etc..?
Thu Jan 13, 2022 3:22 pm
ryanbuckner offline
I was able to replicate this error. I'll get a fix together (as soon as I figure out how).
Fri Jan 14, 2022 1:04 pm
ryanbuckner offline
There's a new version in the Plugin Store.
