Problem with adding attachments after indigo update
Wed Feb 14, 2024 8:12 pm
norcoscia offline
Hi, not sure if this is the place to post or if it should go into the Indigo server section but....
After upgrading to indigo 2023.2 an email that has been sending me attachments every morning stopped sending and errors- I looked at it and it looks like when I try to attach anything I cannot save the action. I get an error - see below. Not sure what to try next as I tried creating a new action and tried several different types of attachments but it always gives me the same error. Help please
PS. I removed the email address for the screen shot but that is not causing the error in red - also nothing shows up in red....
PPS. I have other actions that work fine sending emails but they don't have attachments.
Image 2-14-24 at 6.01 PM.jpg (60.45 KiB) Viewed 971 times
_______
Norm
Thu Feb 15, 2024 12:57 pm
Re: Problem with adding attachments after indigo update
Look in the log. Might need to turn on debug logging. Also try putting quotes around the path string.
Thu Feb 15, 2024 3:20 pm
norcoscia offline
Quotes around the path string did not help.
This is the log error
Screenshot 2024-02-15 at 1.17.52 PM.png (83.01 KiB) Viewed 913 times
_______
Norm
Thu Feb 15, 2024 6:10 pm
I’ll have to check when I get home, but I think that’s a bug I already fixed but is waiting on an Indigo release.
Thu Feb 15, 2024 6:43 pm
norcoscia offline
OK, thanks - strange that no one else has run into this. I have tried a ton of different attachment types and tried them all from several different locations (inside and outside of the Indigo directory). Could not get any attachments to go out.’
Curious if anyone else is able to get any attachments to work.
Either way, thanks and I’ll keep my fingers crossed that it will be fixed soon - I have been keeping an historical record with the charts I email myself for many years…
_______
Norm
Fri Feb 16, 2024 7:21 am
As I recall, that bug was triggered when the file to be attached did not exist at the time the action was created, as it was attempting to validate the file at that point. When you're editing this action, does the file to be attached actually exist? If not, try creating it then saving the action.
Also, make sure the permissions on the file (and all the folders leading to it) allow it to be read by the account Indigo is running under.
If none of that works, grab the fixed version from my repo at https://github.com/FlyingDiver/ID-Email ... Plugin.zip
Fri Feb 16, 2024 8:25 am
norcoscia offline
Thanks, yes the files already exist and all the permissions look good - I’ll try the updated version and report back…
_______
Norm
Fri Feb 16, 2024 8:32 am
norcoscia offline
Link in your post does not work and I only see better email when I search your projects on GitHub
_______
Norm
Fri Feb 16, 2024 8:46 am
Hmm. I forgot that's a private repo. I'll see what I can do to get you a copy.
Sun Feb 25, 2024 2:17 pm
TimH offline
I am having issues with any attachment too using python. See below for a scripting shell example without and with attachment (Fails - RuntimeError: unable to convert python exception)
>>> plugin = indigo.server.getPlugin("com.indigodomo.email")
>>> props = {'emailTo': ‘********@mac.com', 'emailCC': '', 'emailBCC': '' , 'emailSubject': 'Test Email', 'emailAttachments': '', 'emailFormat': 'plain','emailMessage': 'Message Content' }
>>> plugin.executeAction("sendEmail", indigo.devices["smtp.mail.me.com"].id, props=props)
<indigo.Dict object at 0x1062ca5e0>
IN LOG:
Email+ Debug sendEmailAction errors = Item : (dict)
Email+ Debug sendEmailAction queueing message 'Test Email'
Email+ Debug smtp.mail.me.com: SMTP poll, 1 items in queue
Email+ sending email 'Test Email' to '*******@mac.com' using smtp.mail.me.com
Email+ Debug smtp.mail.me.com: sending:
Subject: Test Email
To:******@mac.com
Date: Sun, 25 Feb 2024 12:07:38 -0800
Message-ID: <170889165823.54964.587823607306139250@1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa>
Content-Type: text/plain; charset="utf-8"
Content-Transfer-Encoding: 7bit
MIME-Version: 1.0
>>> props = {'emailTo': '********@mac.com', 'emailCC': '', 'emailBCC': '' , 'emailSubject': 'Test Email', 'emailAttachments': '/Library/Application Support/Perceptive Automation/Charts/Battery_Levels.png', 'emailFormat': 'plain','emailMessage': 'Message Content' }
File "<console>", line 1, in <module>
<NOTHING IN LOG>
<FILE Hierarchy of existing file is READ Everyone>
Sun Feb 25, 2024 2:18 pm
The fixed plugin is waiting on the next Indigo update.
Sun Feb 25, 2024 2:22 pm
TimH offline
One min turn around - thx! Will turn off attachments for the moment and wait for the update.
Tue Mar 19, 2024 10:26 am
berkinet offline
Indigo 2023.2
Exactly the same problem as reported by norcoscia at the top of this thread.
BTW, I did not notice this because of another problem I was unable to fix until last weekend which kept the trigger from reaching the Email+ action.
