Not sending emails at all
Thu Jul 07, 2022 9:36 am
Bildhauer offline
Hello,
what's wrong with my script? It's not sending an email at all:
emailTo = "merckens@gmx.de"
emailBody = u"Device Name\tDevice ID\tLast Reset Timestamp\tCurrent Power (Watts)\tTotal Energy (kWh)\n"
for dev in indigo.devices.iter("props.SupportsEnergyMeter"):
  emailBody += u"{}\t{}\t{}\t{}\t{}\n".format(dev.name, dev.id, dev.energyAccumBaseTime, dev.energyCurLevel, dev.energyAccumTotal)
import datetime as dt
from datetime import date
today = dt.datetime.now()
yesterday = today - dt.timedelta(days=1)
Str_yesterday=str(yesterday.strftime("%Y%m%d"))
import os.path
save_path = '/Users/smerckens/Desktop/Z-Wave Exporte/'
filename = Str_yesterday+".Export des Tagesverbrauchs.txt"
completeName = save_path+filename
file1 = open(completeName , "w", encoding='utf-8')
file1.write(emailBody)
file1.close()
# indigo.server.sendEmailTo(emailTo, subject="Stromverbrauch des Vortages ("+Str_yesterday+")", body=emailBody)
props = {
    'emailTo': emailTo,
    'emailCC': '',
    'emailBCC': '',
    'emailSubject': subject,
    'emailAttachments': filename,
    'emailFormat': 'plain',
    'emailMessage': emailBody
plugin = indigo.server.getPlugin("com.indigo.email")
if plugin.isEnabled():
   plugin.executeAction("sendEmail", deviceId=1948829696, props=props)
Calling the script manually log only shows:
Schedule                        Sende Stromverbrauch täglich + Datei sichern
Thanks in advance for your help!
Bildhauer.
Thu Jul 07, 2022 11:10 am
Re: Not sending emails at all
When getting the plugin instance try using com.indigodomo.email instead of com.indigo.email.
Thu Jul 07, 2022 11:22 am
Bildhauer offline
then I' m getting:
 Email+ Debug                    sendEmailAction queueing message 'Stromverbrauch des Vortages (20220706)'
   Email+ Debug                    Email+ SMTP Server: SMTP poll, 1 items in queue
   Script Error                    embedded script error:
   Script Error                    unable to convert python exception
     embedded script, line 33, at top level
RuntimeError: unable to convert python exception
Thu Jul 07, 2022 11:45 am
Simplify your example to not create an email props with an attachment to see if that works.
Also, did anything send? From the log it looks like a message was queued up.
Thu Jul 07, 2022 1:05 pm
Bildhauer offline
No email was ent.
I'll try without attachment and will come back to you!
Bildhauer
Thu Jul 07, 2022 1:08 pm
Bildhauer offline
Without attachment email was sent. So the referent to the file is wrong?
Bildhauer
Thu Jul 07, 2022 1:15 pm
Bildhauer offline
I changed it to:
import os.path
filename = Str_yesterday+'.Export des Tagesverbrauchs.txt'
file1.close()
props = {
    'emailTo': emailTo,
    'emailCC': '',
    'emailBCC': '',
    'emailAttachments': completeName,
plugin = indigo.server.getPlugin("com.indigodomo.email")
And it's working!
Thanks for your support!
Bildhauer
Sat Jul 16, 2022 9:18 am
roquej offline
This is probably very simple, but I am missing it. The below worked in python 2, but getting "unable to convert python exception"
wsStates = indigo.devices[259796767].states #
def sendAlertEmail(alert, message, expires):
   theSubject = "Miami Weather Alert: %s" % alert
   theBody = "%s\n\nThis weather alert is valid until %s" % (message, expires)
   bePlugin = indigo.server.getPlugin("com.indigodomo.email")
   if bePlugin.isEnabled():
      bePlugin.executeAction("sendEmail", deviceId=762832699,
      props={'emailTo':'email@email.com', 'emailSubject': theSubject, 'emailMessage': theBody})
   return
if str(wsStates[u'alertTitle1']) != ' ':
   sendAlertEmail(wsStates[u'alertTitle1'], wsStates[u'alertDescription1'], wsStates[u'alertExpires1'])
if wsStates[u'alertTitle2'] != ' ':
   sendAlertEmail(wsStates[u'alertTitle2'], wsStates[u'alertDescription2'], wsStates[u'alertExpires2'])
if wsStates[u'alertTitle3'] != ' ':
   sendAlertEmail(wsStates[u'alertTitle3'], wsStates[u'alertDescription3'], wsStates[u'alertExpires3'])
if wsStates[u'alertTitle4'] != ' ':
   sendAlertEmail(wsStates[u'alertTitle4'], wsStates[u'alertDescription4'], wsStates[u'alertExpires4'])
if wsStates[u'alertTitle5'] != ' ':
   sendAlertEmail(wsStates[u'alertTitle5'], wsStates[u'alertDescription5'], wsStates[u'alertExpires5'])
Any suggestions how to fix?
JP
Sat Jul 16, 2022 10:00 am
roquej offline
Sorry folks. I am a certifiable dork. Was using the incorrect SMTP devices.
JP
