Application Authorization Error
Tue Jul 25, 2023 11:53 am
donhoffman offline
Decided to post a new topic rather than using some similar topics, as not sure my issue has same root cause. Like the other authorization issues, the Alexa indigo skill believes my token has expired. When I try to relink (with the "Enable to Use" link in the Alexa app) I fail with "Application Authorization Error" at the redirect to indigodomo.com.
Revoking the Authorization on the Indigo site gets past that error, but the the discovery triggered by the relink seems to fail in the app, but when I try to use Alexa after that all is well. After a day or so, it fails again. Am on third relink at this point.
Two relevant log snippets follow. They are very similar, if not identical.
One other bit of possibly relevant information before I paste in all the logs is that I removed my Homebrew install and as a result, manually cleared out the contents of /user/local. All the subdirs only seemed relevant to Homebrew, but you never know. This issue is at my primary residence. Not having any issues at my second home.
1) This appears in the log at about the time I believe Alexa decides the token is bad. Don't know for sure as I was still in bed at 5am:
   Web Server Error                Attempt to validate token failed
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
    yield
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/backends/sync.py", line 94, in connect_tcp
    sock = socket.create_connection(
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socket.py", line 824, in create_connection
    for res in getaddrinfo(host, port, 0, SOCK_STREAM):
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socket.py", line 955, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 8] nodename nor servname provided, or not known
During handling of the above exception, another exception occurred:
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
    yield
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 218, in handle_request
    resp = self._pool.handle_request(req)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection_pool.py", line 253, in handle_request
    raise exc
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection_pool.py", line 237, in handle_request
    response = connection.handle_request(request)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection.py", line 86, in handle_request
    raise exc
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection.py", line 63, in handle_request
    stream = self._connect(request)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection.py", line 111, in _connect
    stream = self._network_backend.connect_tcp(**kwargs)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/backends/sync.py", line 93, in connect_tcp
    with map_exceptions(exc_map):
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/contextlib.py", line 153, in __exit__
    self.gen.throw(typ, value, traceback)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
    raise to_exc(exc)
httpcore.ConnectError: [Errno 8] nodename nor servname provided, or not known
The above exception was the direct cause of the following exception:
  File "plugin.py", line 235, in verify_token
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_api.py", line 189, in get
    return request(
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_api.py", line 100, in request
    return client.request(
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 821, in request
    return self.send(request, auth=auth, follow_redirects=follow_redirects)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 908, in send
    response = self._send_handling_auth(
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 936, in _send_handling_auth
    response = self._send_handling_redirects(
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 973, in _send_handling_redirects
    response = self._send_single_request(request)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 1009, in _send_single_request
    response = transport.handle_request(request)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 217, in handle_request
    with map_httpcore_exceptions():
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
    raise mapped_exc(message) from exc
httpx.ConnectError: [Errno 8] nodename nor servname provided, or not known
2) This happens after the revoke and relink when the discovery fails. It repeats several times.
Jul 25, 2023 at 10:32:51 AM
    yield
    yield
    raise exc
    raise exc
    raise to_exc(exc)
    return request(
Wed Jul 26, 2023 1:37 pm
Re: Application Authorization Error
