I'm getting mixed results when asking for variables.
Sometimes it works and other times I get "Sorry, I'm having trouble accessing your Indigo Skills skill right now "
jay (support) wrote:[MODERATOR NOTE]: Split to a new topic since it's a different issue.
A couple of questions:
1) Is that the exact wording of the message?
2) Is this when you ask for a variable value or for a list of variables (or both)?
3) Does the error only happen after 6+ minutes of inactivity? In other words, does this only happen after you haven't asked Alexa to do anything from Indigo (control device, run action, get variable) for over 6 minutes, then once you get the error if you try again immediately it works?
FlyingDiver wrote:I do wonder if having the "if" in the name is causing Alexa to try to apply that to the skill rather than as part of the name.
Try renaming the variable.
jay (support) wrote:Turn on debugging in the Alexa menu, then perform the command again. Copy/paste anything that shows up as a result.
Jun 28, 2021 at 11:55:18 AM
Alexa Debug variable_actions API call received
Alexa request the value of variable 'garage_door_status'
Alexa Debug reply:
{"speak_string": "<Both garage doors are closed", "status": "success", "variable_name": "garage door status", "variable_name_mangled": "garage_door_status"}
