Failed to update control info / Failed to update sensor
Sat May 20, 2023 10:12 pm
Bleasel offline
Thanks again Neil for the Plugin
I have been getting the following errors (not new, but they don't seem to cause any issues), ie the device states correctly show the mode, and I can change the modes.
Daikin Wifi Controller Unknown/Other Error getting /aircon/get_sensor_info from Daikin Unit Level 3 AirCon
Daikin Wifi Controller Error Failed to update sensor Level 3 AirCon aborting state refresh
Daikin Wifi Controller Unknown/Other Error getting /aircon/get_control_info from Daikin Unit Level 3 AirCon
Daikin Wifi Controller Error Failed to update control info Level 3 AirCon aborting state refresh
If I enter:
http://192.168.1.11/skyfi/aircon/get_control_info
or
http://192.168.1.11/skyfi/aircon/get_sensor_info
I get a valid returns of information.
Wondering whether this has anything to do with me needing to enter "192.168.1.11/skyfi" as my Ip address in the Config.
Marcus
Fri Jan 26, 2024 7:31 pm
mclass offline
Re: Failed to update control info / Failed to update sensor
Hi Neil,
I too, am getting a similar error as follows:
Daikin Wifi Controller          HTTP Error getting /aircon/get_control_info from Daikin Unit Ground Floot A/C
   Daikin Wifi Controller Error    Failed to update control info Ground Floot A/C aborting state refresh
I have extended the polling frequency and the time out settings to no effect.
The Daikin app (Version 4.8.0) has no issue in communication with the AC unit, nor does the Hubitat Daikin device (which is usually disabled) . Done all the usual things such as rebooting (Mac Mini, Daikin AC unit and router) to no avail. .
There are reports that the firmware of the Daikin wifi adapter was updated about August 2023 (see https://github.com/home-assistant/core/issues/99251. The iOS Daikin app reports that my wifi adapter firmware is 2.8.0.
I'm running Daikin WiFi controller plugin 2022.0.6, OSX 10.13.6 and Indigo 2023.2, although the error became apparent when running Indigo 2022.1, so the Indigo upgrade appears not to be the issue, but the Daikin wifi adapter maybe?
Any assistance appreciated!
Neil
Mon Jan 29, 2024 3:26 pm
neilk offline
Sorry I missed this and I am travelling this week. I think as you say the controller just periodically fails to respond regardless of refresh rate. Let me take a look at tracking/logging this more intelligently such that it only errors after a number of retries.
It will be the weekend before I can take a look.
Neil
Sat Mar 16, 2024 2:31 pm
Stoutjesdijk offline
Hi Neil,
I, too, am still getting those errors. Have you had a chance to look at this yet?
Much appreciated!
Mark
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
Mon Mar 18, 2024 3:41 am
neilk offline
I did look at the time and couldn’t replicate it. I then got distracted. I took a look and it appears to be happening again for me so I will tidy up the logging as promised.
Neil
Sun Mar 24, 2024 1:09 pm
neilk offline
A quick update, I found some time this weekend to update the logging and make this configurable such that you can set the logging level if you are experiencing problems, otherwise these issues will be silent. I need to test it for a while as the error is fairly intermittent, but expect a new version to test early in the week.
Neil
Fri Apr 19, 2024 5:58 pm
mclass offline
Hi Neil,
Any update on progress on this issue?
mclass
Sat May 04, 2024 3:58 am
neilk offline
Sorry been tied up on a number of things, and have not had much Indigo time. I have done most of the work but keep tweaking the right way to present/supress this having finally moved to proper logging. Bank Holiday here this weekend so will carve out some time.
Neil
Mon May 06, 2024 1:03 pm
neilk offline
Please try this test version https://github.com/neilkplugins/Daikin-Wifi-indigo-plugin/releases/tag/2024.0.2-alpha\
This moves to the correct logging approach and with logging set for critical only then it should stop the errors.
Neil
Thu May 09, 2024 6:35 pm
mclass offline
Hi Neil,
Thankks for your efforts on this plugin.
Apologies for delay in responding - I have been away without access to my Indigo system.
I have upgraded to your new version, with the following result (debugging on):
 Enabling plugin "Daikin Wifi Controller 2024.0.2" using API v3.0
   Starting plugin "Daikin Wifi Controller 2024.0.2" (pid 87836)
   Started plugin "Daikin Wifi Controller 2024.0.2"
   Daikin Wifi Controller Debug    startup called
   Daikin Wifi Controller Error    HTTP Error getting /aircon/get_control_info from Daikin Unit Ground Floot A/C
   Daikin Wifi Controller Debug    Error is 404 Client Error: Not Found for url: http://X.X.X.XXX/aircon/get_control_info
   Daikin Wifi Controller Debug    Failed to update control info Ground Floot A/C aborting state refresh
   Daikin Wifi Controller Debug    Last Update 2024-01-16 22:11:34
   Daikin Wifi Controller Debug    Empty data aborting state updates
   Daikin Wifi Controller Error    exception in device_start_comm(Ground Floot A/C): name 'datetime' is not defined
   Daikin Wifi Controller Debug    Starting concurrent thread
   Daikin Wifi Controller Error    Error in plugin execution runConcurrentThread:
  File "plugin.py", line 463, in runConcurrentThread
  File "plugin.py", line 208, in _refreshStatesFromHardware
type: name 'datetime' is not defined
   Daikin Wifi Controller Error    plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Daikin Wifi Controller Debug    Error is 404 Client Error: Not Found for url: [code]http://X.X.X.XXX/aircon/get_control_info[/code]
I have checked that the AC unit is online - it's accessible via the app, and in the browser, although the response to the "not found" URL is:
Page Not Found
Downgrading the plugin to version v2022.0.1 resumes operation with the same errors as previously reported with that version.
The Daikin adapter firmware version is 2.8.0, and auto update is on, so presumably latest Daikin firmware.
Thanks again for your work on this plugin!
Thu May 09, 2024 8:57 pm
mclass offline
Oh dear!
On further hunting around, it appears that the upgrade to the Daikin wifi module to V2.8.0 is the culprit :cry:
See https://github.com/home-assistant/core/issues/99251
Without much coding knowledge, I suspect that this might require a major re-write of the plugin, in which case I will need to stick with the iOS app rather than Indigo.
mclass :roll:
Fri May 10, 2024 12:50 am
neilk offline
Thanks for the update, other than a stupid mistake on my part nothing in the new version should cause that, strange when you rolled back it worked, as it only changed the logging details.
I have resisted moving to the new version of the app that is published here as I know it has a different authentication model, and it looks like it forces a firmware update .
It may not even be possible to update this to support the new firmware and features differed across regions !
Neil
Sat May 11, 2024 2:01 am
neilk offline
I have done a little more digging and indeed the firmware update does disable the local API and forces the use of their cloud API which is quite restrictive.
I am afraid I will be sticking with the current version and not adding support for the cloud API
Some has built an alternate controller with local API https://github.com/revk/ESP32-Faikin
Which I would explore if the status quo needs to change !
Neil
