Thermostat settings do not stick
Thu Jun 17, 2021 2:54 pm
neilk offline
Re: Thermostat settings do not stick
Thanks - so it is being reported correctly. I found a similar error in the log on my production machine. I will see if I can replicate further. Is this error intermittent for you ?
Neil
Tue Jun 22, 2021 10:01 am
mkbean offline
It seems intermittent on some units but happens nearly every time on 2 or 3 units (I have 6 units). The response i sent was from one of the ones that seems to fail almost all the time.
Tue Jun 22, 2021 12:01 pm
neilk offline
Ah - I suspect that these units are using NodeMCU or equivalent hardware and are a little underpowered. I will take a look and see if I can trap this more elegantly. My unit has a fault at the moment so waiting for a replacement before I can properly test.
Neil
