Solcast Solar Forecast released for Indigo 2022.1/Python 3
Sat May 14, 2022 4:24 am
neilk offline
Initial release of the Solcast Plugin published to the Plugin Store https://www.indigodomo.com/pluginstore/265/ (Pending Approval)
Or on Github https://github.com/neilkplugins/Solcast-indigo-plugin/releases/tag/2022.0.2
Support for prior Indigo versions https://github.com/neilkplugins/Solcast-indigo-plugin/releases/tag/2021.0.1
Note: Edited to add a version for the 2.0 API/Indigo 2021 to fix the API authentication issue
Sat May 14, 2022 10:38 am
neilk offline
Re: Solcast Solar Forecast released for Indigo 2022.1/Python
Updated version to address a change in authorisation approach in the Solcast API. My existing key continued to work, so I missed this in testing but the change is enforced for newly generated API keys. As a side note the existing key does not show in my account and cannot be deactivated, I will raise this with them.
Thanks and apologies to Chase for spotting the issue.
Neil
This will be pushed to the plugin store when approved
