Hi all,
Paradox Alarm IndigoPlugin
Thought would post this mostly completed plugin - but it working so well for me I may not have much need to update down the track.
Download GITHUB:
https://github.com/Ghawken/SpectrumIndigo/
Press the Clone/Download button for the moment...
Aim:
Alarm system plugin for Paradox SP5000/SP6000/SP7000 (I have SP7000 and all working)
Need a IP150 device to connect panel serial port to network.
Other than that should be fairly self-explanatory....
Personally I find the instant on/and a few seconds off motion detection fantastically useful, and now have added the Alarm to other sensors, may be close to full occupancy recogntion/following etc.
About
For Zone status, & Control of MG5050, SP6000 Paradox Alarm systems.
Compatibility:
- MG5050 V4 IP150 Fully supported using the MG5050 mappings
- SP6000 IP150 Supported using the MG5050 mappings
- SP65 ? Supported
- EVO Series Unknown... (labels apparently not working)
Needs IP150 Model connected to Alarm System. Like this one:
Beta plugin at the moment - Zone and Alarm control working well for myself at the moment - so may not get time to get back to it.
Thought reasonable as fills hole to release as Beta currently and can see how others go.
Setup:
Pretty Basic - biggest part is passwords and IP Address:
Passwords as per the Config Screen.
Then Create Main Device:
Then Create as many Zone Sensors devices as you have/wish to monitor
Triggers
The plugin captures a lot of Alarm information and additionally triggers on it all.
Actions
With the plugin you can enable, disable, arm, stay-d, sleep mode turn on/turn off and enable PGM's
