Version 1.4 not publishing to HA
Fri May 13, 2022 8:20 am
Umtauscher offline
Hi wonderslug,
I just found your great plugin and installed it. Wow, that was I needed!
Unfortunately the communication was a one way street as I couldn't get any state change from Indigo -> HA.
So I tried, the other Homeassistant plugin to get my Aqara Sensors into Indigo.
But this plugin doesn't publish anything to HA - but I think it isn't supposed to.
So I tried you plugin again, switching to debug mode but I couldn't get anything when a sensor changed in the log, so I think it simply doesn't get triggered.
I was desparate and tried downgrading to 1.3 and voilà the plugin worked instantly both ways! Yeah! I am really happy now.
Nevertheless I wanted to let you know of this problem. I am using Indigo 7.5 with the latest HA core-2022.5.4 and my Mosqitto broker running on my MacMini Server.
The MacOS is still Sierra. 10.12.6
Any Idea what could cause the problem?
(I hope this plugin is still supported)
Thanks anyways for your great plugin.
Cheers
Wilhelm
Sun May 22, 2022 1:46 am
Umtauscher offline
Re: Version 1.4 not publishing to HA
Ok, since nobody seems to know, I found out myself by accident.
You have to install the plugin twice. The second time it works.
It doesn‘t matter if you install 1.3 -> 1.4 or 1.4 -> 1.3
Seems to be an initialization issue.
I have 1.4 now running fine.
