Hass plugin install issues
Sat Oct 02, 2021 10:03 am
pxzel offline
Can't seem to get the plugin to start on M1 Mac mini running Indigo 2021.1.1
Any ideas?
Log errors:
Installing and enabling plugin HassBridge v1.4.0
Loading plugin "HassBridge 1.4.0"
Starting plugin "HassBridge 1.4.0" (pid 867)
HassBridge Error Error in plugin execution InitializeMain:
File "plugin.py", line 93, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/HassBridge.indigoPlugin/Contents/Server Plugin/__init__.py", line 53, in __init__
ValueError: invalid literal for int() with base 10: ''
Stopping plugin "HassBridge 1.4.0" (pid 867)
Stopped plugin "HassBridge 1.4.0"
Sat Oct 02, 2021 10:15 am
WonderSlug offline
Re: Hass plugin install issues
If you have a value in the MQTT Settings:Server Port make sure it is a valid number only with no spaces or other strings around it.
If thats not the problem there might be something odd with the handling of the python version in Indigo (which is an old 2.7 version) on a M1 CPU.
Sat Oct 02, 2021 11:16 am
pxzel offline
There is no configure setting when I use the plugin dropdown menu. I'm running
Python 3.8.2
Python 2.7.16
Sat Oct 02, 2021 3:17 pm
WonderSlug offline
It doesnt matter what version of python you have on your machine. Its the embedded python in Indigo
Sat Oct 02, 2021 4:03 pm
Indigo uses the python 2.7 install that comes with macOS. Third party python installs other than the one directly from python.org can cause issues.
Sat Oct 02, 2021 4:44 pm
pxzel offline
Well, I'm pretty sure both of the Python versions came with my M1 Mac. I've read other posts that state that 2 versions come with m1 Mac Big Sur 11.6.
Can anyone verify what Python versions Indigo works with?
Sat Oct 02, 2021 6:12 pm
Yes, newer macOS releases come with both. Indigo will use the 2.7 version.
Sat Oct 02, 2021 6:19 pm
pxzel offline
So, is it safe to assume that the Home Assistant and Hassbridge plug-in have issues with M1 and Big Sur? I never used those plugins and just recently tried to activate them. When I initially activated them, today, they both allowed me to enter configuration parameters. But after I tried to save, the config menu disappeared for each.
After trying to reinstall, the config menus never showed up again.
Tue Oct 05, 2021 2:12 pm
pxzel offline
I think its fixed. I deleted the plugins preference file and the plugin is working correctly now. Thanks for the help.
