Discovered Device list is empty
Wed Jan 19, 2022 6:37 am
MarcoGT offline
Hi all,
I am new to the Shelly Setup; I try to explain what I have done so far.
1. Docker with mosquitto-eclipse running
2. MQTT Explorer connects to mosquitto-eclipse and I see "shellies/announce"
3. I have a MQTT Broker (Plugin MQTT-Connector) connected to the MQTT server (is green)
4. I try to add a Shelly PlugS but I do not see anything in the list
Any help?
For sure it is a dumb question :)
Wed Jan 19, 2022 6:46 am
MarcoGT offline
Re: Discovered Device list is empty
Ok, now I have enable MQTT on the plug (by default it was disabled, I did not know that);
I see the plug announced in the MQTT Explorer, but the list in still empty; maybe the topic counts?
Wed Jan 19, 2022 6:55 am
MarcoGT offline
Here a screenshot
From my understanding, the shellyMQTT plugin looks for the "shellies" topic, am I right?
I added "shellies/" the subscribed topic inside the MQTT Connector
Wed Jan 19, 2022 7:28 am
tazswe offline
Have you made a device for the plug?
Have you made a trigger?
Sent from my iPad with Tapatalk
Wed Jan 19, 2022 7:30 am
MarcoGT offline
I tried to make a device by selecting "ShellyMQTT" as model, but it here where the device list is empty
And yes, I created a trigger as explained here
https://github.com/AaronLionsheep/Shell ... ng-Started
Wed Jan 19, 2022 7:52 am
tazswe offline
What version do you use?
try to get the latest here https://github.com/AaronLionsheep/ShellyMQTT/releases
normaly you should have a list of all type of devices to choose from.
try to restart the plugin.
Wed Jan 19, 2022 7:59 am
MarcoGT offline
But the menu plugin says the that latest version is 0.3.0 :)
Now I installed 0.7.1
BTW, I have created the trigger, but which action shall be fired when the trigger is met?
The attachment shows the drop down list when trying to add a device
Wed Jan 19, 2022 8:11 am
MarcoGT offline
This is what I have when I print the subscribed topics:
MQTT Connector                  Local MQTT: Current topic subscriptions:
   MQTT Connector                  Local MQTT: shellies/# (0)
"shellies" is the topic specified in the MQTT Connector device
Wed Jan 19, 2022 8:30 am
tazswe offline
Mqtt broker, the same name as your broker
Mqtt topic root, shellies/shellyplug-s-B4B29E
Message type, shellies
Wed Jan 19, 2022 8:31 am
tazswe offline
You should leave the action empty when you fire the trigger.
Wed Jan 19, 2022 9:43 am
MarcoGT offline
Ok, it works, the problem was the topic root, "shellies" was missing;´.
Very nice, thank you!
