When is a Shelly Dimmer not a Shelly Dimmer -UPDATED-
Sat Apr 18, 2020 7:35 am
CliveS offline
UPDATED
Since I wrote this Joe came back with a much better way with his HTTPd v2 server,
I have changed over to it and no more editing a python script. Thanks Joe!
FlyingDiver wrote:
See viewtopic.php?f=216&t=23833&p=190742#p190742 for my way of doing it. ;)
And thanks for pointing out that IOS shortcuts can do a web request. I had no idea. I can actually use this to remove a
bunch of stuff from HKB.
Answer.
When it is running an Indigo Action instead.
Decided to learn about IOS shortcuts and one thing led to another.
So with an iPhone/iPad/AppleWatch ect that runs Siri/Shortcuts you can now run any Action you have in Indigo with just a Shelly Dimmer (97 Actions per Dimmer - if you need more then just get another Dimmer or if you have a load of Actions you can control over 1000 by using a Shelly RGBW) and Aaron's ShellyMQTT plugin, no homebridge required.
Install ShellyMQTT and give your Dimmer a fixed IP and add to ShellyMQTT.
Run IOS Shortcuts and add a New Shortcut, Add Action, Web, Web Requests, Get Contents of URL and fill in using your Shelly Dimmer IP.
Shortcut
For every Shortcut give it a different Brightness value between 2 and 99.
To speed adding shortcuts you can use the duplicate shortcut and edit just the brightness value and the shortcut name.
Shortcut Duplicate
Now write a python script to get the "brightness" and use it to run the correct Action.
Excuse my beginners Python, please if you can improve this I would love to see it added below.
# Shelly Dimmer Used As Indigo Action Server
# CliveS 18 April 2020
# Improvements Appreciated
# Caveat
# Shelly Dimmer Needs Brightness to Be 0
# Trigger Settings
# Type :   Device State Changed
# Device:   Your Shelly Device
#         Brightness Level
#            Becomes Greater Than 0
# Condition:Always
# Actions:   Execute Script (This Script)
# Use Your Own Device And Action Groups
devShellyDimmer         = indigo.devices[1423936141]      # "Shellydimmer-CC50E3F3A8BA"
actNullAction         = indigo.actionGroups[368675060]  # "NullAction"
actDriveLightsOn      = indigo.actionGroups[267790534]  # "Drive Lights On"
actDriveLightsOff      = indigo.actionGroups[148839790]  # "Drive Lights Off"
actBedroom1LightOn      = indigo.actionGroups[1305866272] # "Bedroom 1 Ceiling Light On"
actBedroom1LightOff      = indigo.actionGroups[1848420604] # "Bedroom 1 Ceiling Light Off"
actConservatoryLightOn   = indigo.actionGroups[1194598329] # "Conservatory Light On"
actConservatoryLightOff   = indigo.actionGroups[1137618911] # "Conservatory Light Off"
actDiningRoomLightOn   = indigo.actionGroups[1024095698] # "Dining Room Lights On"
actDiningRoomLightOff   = indigo.actionGroups[684964061]  # "Dining Room Lights Off"
actKitchenLightOn      = indigo.actionGroups[1397879272] # "Kitchen Spot Lights On"
actKitchenLightOff      = indigo.actionGroups[1928612426] # "Kitchen Spot Lights Off"
actLivingRoomLightsOn   = indigo.actionGroups[92742435]   # "Living Room On and Hall Lamp 50% No Time Check"
actLivingRoomLightsOff   = indigo.actionGroups[1534354226] # "Living Room and Hall Lamp Off No Time Check"
actPanasonicTVOn      = indigo.actionGroups[148983306]  # "TV On"
actPanasonicTVOff      = indigo.actionGroups[720380761]  # "TV Off"
actFrontDoorOpen      = indigo.actionGroups[41446900]   # "Unlock Front Door"
actGarageOpen         = indigo.actionGroups[311559716]  # "Garage Door Left Open"
actGarageClose         = indigo.actionGroups[710225838]  # "Garage Door Left Close
State   = "brightnessLevel"
dev      = indigo.devices[devShellyDimmer]
x      = dev.states[State]
indigo.server.log(" ")
if x < 2 or x > 99:
   # indigo.server.log(unicode(dev.states[State]))
   # indigo.server.log("Not Between 2 and 99")
   pass
   # indigo.server.log("Between 2 and 99")
   # indigo.server.log("x = " + str(x))
   if x == 2:
      indigo.server.log("x = 2")
   if x == 3:
      indigo.server.log("x = 3")
   if x == 4:
      indigo.server.log("x = 4")
   if x == 20:
      # indigo.server.log("Dining Room Light On")
      indigo.actionGroup.execute(actDiningRoomLightOn)
   if x == 21:
      # indigo.server.log("Dining Room Light Off")
      indigo.actionGroup.execute(actDiningRoomLightOff)
   if x == 22:
      # indigo.server.log("Kitchen Light On")
      indigo.actionGroup.execute(actKitchenLightOn)
   if x == 23:
      # indigo.server.log("Kitchen Light Off")
      indigo.actionGroup.execute(actKitchenLightOff)
   if x == 24:
      # indigo.server.log("Living Room Light On")
      indigo.actionGroup.execute(actLivingRoomLightsOn)
   if x == 25:
      # indigo.server.log("Living Room Light Off")
      indigo.actionGroup.execute(actLivingRoomLightsOff)
   if x == 26:
      # indigo.server.log("Conservatory Light On")
      indigo.actionGroup.execute(actConservatoryLightOn)
   if x == 27:
      # indigo.server.log("Conservatory Light Off")
      indigo.actionGroup.execute(actConservatoryLightOff)
   if x == 28:
      # indigo.server.log("Bedroom 1 Light On")
      indigo.actionGroup.execute(actBedroom1LightOn)
   if x == 29:
      # indigo.server.log("Bedroom 1 Light Off")
      indigo.actionGroup.execute(actBedroom1LightOff)
   if x == 30:
      # indigo.server.log("Drive Lights On")
      indigo.actionGroup.execute(actDriveLightsOn)
   if x == 31:
      # indigo.server.log("Drive Lights Off")
      indigo.actionGroup.execute(actDriveLightsOff)
   if x == 80:
      # indigo.server.log("Panasonic TV On")
      indigo.actionGroup.execute(actPanasonicTVOn)
   if x == 81:
      # indigo.server.log("Panasonic TV Off")
      indigo.actionGroup.execute(actPanasonicTVOff)
   if x == 90:
      # indigo.server.log("Open Front Door")
      indigo.actionGroup.execute(actFrontDoorOpen)
   if x == 98:
      # indigo.server.log("Open Garage Door")
      indigo.actionGroup.execute(actGarageOpen)
   if x == 99:
      # indigo.server.log("Close Garage Door")
      indigo.actionGroup.execute(actGarageClose)
if x != 0:
   indigo.device.turnOff(dev)
   #indigo.server.log(unicode(dev.states[State]))
   pass
   pass
Finally add a Trigger with the following setup
# Trigger Settings
#           Brightness Level
# Condition:Always
# Actions:   Execute Script (Name You Gave Above Script)
When you first run a new Shortcut it will ask for permission but remembers after that
Permission Required
You will end up with Shortcuts in the Widget (if required) and Hey Siri will do what you want :)
Anyone know how to change the button colours, my OCD hates the two colours, I would like them all one colour :roll:
Widget Menu
Just as a test I added "Hey Siri, Shelly" and my drive lights came on and "Hey Siri, Indigo" turned them off again, usually I would use Turn On Drive Lights or Drive Lights On but impressed Siri now does not need Open/Close/Turn On/Off commands.
"Hey Siri, Shelly"
   ShellyMQTT                      "Shellydimmer-CC50E3F3A8BA" on to 30%
   Script
   Action Group                    Drive Lights On
   ShellyMQTT                      "Shellydimmer-CC50E3F3A8BA" off
"Hey Siri, Indigo"
   ShellyMQTT                      "Shellydimmer-CC50E3F3A8BA" on to 31%
   Script
   Action Group                    Drive Lights Off
I have asked Aaron about silencing the logging per device and he is adding that option in a few days so the "Shellydimmer-CC50E3F3A8BA" on to 30% and "Shellydimmer-CC50E3F3A8BA" off should be silent.
My thanks to Aaron for a great plugin and Joe for the MQTT Connector.
Hope someone finds this helpful and if you do and can improve my basic python, great!
CliveS
Sat Apr 18, 2020 8:31 am
aaronlionsheep offline
Re: When is a Shelly Dimmer not a Shelly Dimmer
This is was not one of the ways I imagined the plugin being used, but it is definitely a neat way of interacting to Indigo without using HomeKit.
I think you can set the color by editing the action, clicking on the icon, and then you can select a custom "colour". Maybe you could have your On/Open one color/colour and your Off/Close another color/colour :D
Yes, individual device muting is on my mind, so hopefully I can get an elegant solution figured out. No "ah-ha!" moments as of yet though...
Out of curiosity, your logs show:
"Hey Siri, Shelly"
   ShellyMQTT                      "Shellydimmer-CC50E3F3A8BA" on to 30%               <-------- Whats up with this duplicate on?
   Script
Is this second "on" getting logged with every brightness set? I would expect that line to be logged once.
I'm glad you are finding it useful. When Joe showed off MQTT Connector aimed as a utility of other plugins, I was curious to see how it would be used by the plugin developers. As it turns out, I have been able to make, in my opinion, a pretty neat plugin with it.
Sat Apr 18, 2020 8:37 am
Colly offline
Great work.. now I’m wondering if I should update my latest Shelly order to include a dimmer..
Sat Apr 18, 2020 11:31 am
CliveS offline
"Hey Siri, Shelly"
   Script
The first line is the Trigger, the second is the Action, if I just change the value from the dimmer GUI it only fires once.
CliveS
Sat Apr 18, 2020 11:43 am
CliveS offline
Not sure if you have a Shelly 2.5 spare but if so I am sure you could use
http://192.168.0.40/roller/0?roller_pos=30 Will Open at 30%
And use roller_pos = 2-98 and possibly roller/1 as well for another 100, not sure as I don't have one to test.
Just imagine what you could do with an RGBW
http://192.168.0.50/color/0?turn=on&red=255&green=86&blue=112&white=0
 That lot would give 1000 and if you run out just add another 100 with
http://192.168.0.50/color/0?turn=on&gain=27 Change the intensity or RGB to 27%
CliveS
Sat Apr 18, 2020 2:51 pm
Not to be a downer here, but couldn't you do this exact thing with the HTTPd plugin and no Shelly devices at all?
Sat Apr 18, 2020 3:28 pm
CliveS offline
Joe, I am sure you can but I have no idea how to set it up, read the wiki and still none the wiser what httpd actually does or what it is used for except you used it to interface IFFTT to Indigo.
CliveS
Sat Apr 18, 2020 3:39 pm
It's used to handle incoming HTTP requests just like you're doing in the first post. In that case, you're sending it to the Shelly device. Using the plugin, you would be sending it directly to the Indigo server.
I think I'll set up some actions using your iOS shortcut method and the HTTPd plugin, instead of using HKB and post the setup for comparison.
Sat Apr 18, 2020 4:09 pm
CliveS offline
Sounds good , more things to learn during lockdown
CliveS
Sat Apr 18, 2020 6:47 pm
And thanks for pointing out that IOS shortcuts can do a web request. I had no idea. I can actually use this to remove a bunch of stuff from HKB.
Sat Apr 18, 2020 9:09 pm
Thanks for the writeup, I think this has brought to light a new way to interface from iOS to Indigo.
HomeKit seems to work "well" when it works well. I think a few people will start experimenting with this now.
