farberm wrote:Any way to change the interval for checking location to be a set time ( 5 minutes). All I see is a minimum of 15 minutes?
vtmikel wrote:I'm finding that the battery level property is inconsistent in Find my iDevices. When I log into iCloud and check the battery status and level, iCloud seems to have the information correct. However, I created variables to hold these states with triggers to update the variables based on device states and I'm getting battery levels of zero quite often. Anyone else having this problem?
Find My IDevices Error Unable to reach update server.
25 Jul 2014 18:16:30
Find My IDevices Manual iDevice Update Requested (from Menu)
indigo.server.log ("Trigger Error. Unable to process Trigger, due to bad map point [%s]" % mp_trigger_name, is_Error = True)
haavarda wrote:Hi,
I just started to test out this plugin. I have had some small issues.
When I enable the plugin it takes a long time before anything happens after a while it says it was unable to find the update server.
- Code: Select all
I am also unable to update the location manually (from the menu or a control page). This is the biggest problem for me, as I was planning on triggering position updates when something happens...
When I try to manually update position it says to in the event log, but nothing happens. I have set the interval to 1 hour, and this interval seams to work.
- Code: Select all
I have also set the units to km, but it is displayed as miles on the map, Is this something that is familiar?
hope someone that has been using this plugin for a while can share some thoughts on this...
Jpaction wrote:I just started to receive the following error. I have not updated or changed anything. Basically the error says (DeviceName): global name 'urllib2' is not defined
