Find My iDevices! (April 2013+)
Mon May 20, 2013 5:54 am
Dewster35 offline
Re: Find My iDevices! (April 2013+)
Just updated to Indigo Beta 8 and I'm getting the following message over and over again in my event log.
I've reloaded the plugin and I've also rebooted the mac. Any suggestions for a resolution?
Find My IDevices Done registering Apple ID
Mon May 20, 2013 6:45 am
Beta 8 caused an incompatibility with a couple of plugins that were overriding a specific callback (deviceUpdated). I believe Benjamin has the fix now, so hopefully he'll get a new build posted soon.
Mon May 20, 2013 7:07 am
Dewster35 offline
Sounds good, thanks for clarifying Matt.
Tue May 21, 2013 7:33 am
Dewster35 offline
With Ben being out of town for a bit, I decided to dive in and poke around a bit myself. I modified Plugin.PY of FMID. These are lines 440-444. I cannot say whether or not this will work long term or if the distance information will continue to be correct or not. I do know that it corrects the message from popping up in the event log and it still allows me to send my important messages to my phone via find my iphone, so it serves my needs.
   #def   deviceUpdated ( self, origDev, NewDev):
   #   self.remove_device_record ( origDev )
   #   self.deviceStartComm ( NewDev )
Wed May 22, 2013 10:05 am
bschollnick2 offline
Okay, as Matt indicated, that change will work and I've been testing this on and off for a short bit.
Thanks for your patience.
- Ben
for v5 - http://bit.ly/T6WBKu
Wed May 22, 2013 10:13 am
Dewster35 offline
Ben,
Still seeing this same behavior with the latest update.
Wed May 22, 2013 10:18 am
Ben,
My mistake. I zipped up the wrong file.
Give it a moment, and redownload the file from dropbox. The fix is now in there.
Wed May 22, 2013 10:50 am
Dewster35 offline
Ben,
No worries. Thanks Ben! You rock :)
Wed May 22, 2013 10:26 pm
andrewhorvath offline
Hi Ben
Great Plugin. It was working fine, until I added one more phone. I deleted the devices and the plugin, but I am still getting this error message:
Find My IDevices Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 966, in runConcurrentThread
File "plugin.py", line 865, in run_search_for_idevices
File "plugin.py", line 712, in fetch_updated_MobileMe_Locations
File "plugin.py", line 785, in process_device
<type 'exceptions.KeyError'>: key id 1043130764 not found in database
Find My IDevices Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Thank you
Thu May 23, 2013 1:50 am
tenallero offline
This new release works fine with b8.
Thanks.
Thu May 23, 2013 8:08 am
andrewhorvath wrote:
Hi Ben
Was this with v1.715 that was just released yesterday? Or an earlier version?
Thu May 23, 2013 9:39 am
DaSerg offline
Good Morning Ben,
I am having this issue with the latest version, in case Andrew doesn't respond... 1.715..
The webpage does load, but does not show any devices.
May 23, 2013 8:34:26 AM
  Find My IDevices                location: None
  File "plugin.py", line 741, in process_device
<type 'exceptions.IndexError'>: list index out of range
  WebServer                       Displaying Find My iDevices Web Page
  Find My IDevices                   Retrieving location data
Fri May 24, 2013 4:11 am
DaSerg wrote:
Good Morning Ben,
Well, something isn't right there. The Location: None makes me think that FMID isn't configured properly.
Do you have an Apple ID device created, with your proper Apple ID ?
How many FMID devices do you have configured? Have you tried to Restart the FMID plugin?
- Ben
Fri May 24, 2013 11:43 am
DaSerg offline
Yup followed your instructions on your website, I have the location as well as iCloud login as well as iPhones registered... I am PMing you screenshots as it appears to have a key inside of it.
The Apple ID does show as working and accepted with the Password_Accepted field.
I only have one iPhone on one account.. Once this starts working properly I will add the wife's account as well. Used your plugin in the past and worked great.
Thu May 30, 2013 12:28 am
Re: Find My iDevices! (April 2013+) does not ask for devices
I am using indigo 6.00b8.
followed instructions:
- downloaded file from server
- double-clicking on plugin
- moving file into the proper directory (btw the directory given /Plugins/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/Plugins should not have the first /Plugins before Library?)
- restart server
readme text:
5) After the Indigo server restarts, it will immediately open a dialog window,
asking you to the set the default settings for the find-my-iDevice plugin.
==> a) Please ensure that you add the MobileMe account information for the iDevices you wish to monitor. <== does not show up.
the web pages with my home location is fine
any advice?
here the log file after restart of indigo
Disabling plugin "Find My IDevices 1.715"
Stopping plugin "Find My IDevices 1.715" (pid 99466)
Stopped plugin "Find My IDevices 1.715"
Enabling plugin "Find My IDevices 1.715"
Starting plugin "Find My IDevices 1.715" (pid 99623)
Find My IDevices Debug Version Check Server reports 1.30 is available for Find My IDevices.
Find My IDevices Debug You are currently running the release version, or a newer version, of Find My IDevices
Find My IDevices Debug Version Check Server reports 1.41 is available for the Find My iPhone Engine.
Find My IDevices Debug FMID 1.41
Find My IDevices Debug FMID loaded 1.41
Find My IDevices Debug You are currently running the release version, or a newer version, of the Find My iPhone Engine
Started plugin "Find My IDevices 1.715"
Find My IDevices Find My iDevice Plugin Loaded...
Find My IDevices Debug UpdateTime - 15
Find My IDevices Debug Debug Mode is On (Only recommended for Testing Purposes)
Find My IDevices Debug Running Concurrent Thread
Find My IDevices Done Locating all iDevices
Find My IDevices Debug Sleep Time - Thu May 30 01:18:47 2013
Find My IDevices Preferences were updated, reloading Preferences...
