Switchlink has helped me keep my KPL states in sync with various scenes, actions, and triggers that fire. I have three examples for how I use Switchboard to help keep my KPL in sync.
Here is the first one:
Button 8 on my KPL is labeled 'Away'. When I toggle it on, about 9 defined devices will turn off in the master bed and bath area. Great. However, if I then changed the state of any of those 9 devices to on or brightness > 0, KPL 8 would then still be toggled 'On' with the LED illuminated giving a false indication that area of the house was completely off. Switch board solved this by helping keep everything in sync. I have one monitored group named Master Suite which monitors those 9 devices.
A trigger has been created to take action when something in monitored the devices group meet a specific criteria:
- Screen Shot 2012-09-09 at 1.58.16 PM.png (22.97 KiB) Viewed 4187 times
When any of those 9 devices is turned on, the above criteria is met then the action below is accomplished.
- Screen Shot 2012-09-09 at 1.58.30 PM.png (25 KiB) Viewed 4187 times
This is a simple way to keep the state of the KPL button in sync with what is actually going on in that 'zone' or 'group'.
So what about the reverse. We know I can turn off all of those 9 devices by toggling KPL8 on. But if I use Indigo touch to turn the devices off then the KPL8 'Away' button will be toggled 'Off' once again giving a false indication, in this case, that there is still a device on somewhere when in fact everything is off. So I simply reversed the above trigger:
- Screen Shot 2012-09-09 at 2.07.38 PM.png (23.15 KiB) Viewed 4187 times
When the above criteria is met, in this case all 9 monitored devices are off/false the below action is accomplished.
- Screen Shot 2012-09-09 at 2.07.46 PM.png (24.74 KiB) Viewed 4187 times
So as I add more and more devices to my house this group can monitor all of them and take action based on meeting a simple true or false criteria giving me that desired visual LED feedback. I have two other KPL/Switchboard examples that I have setup which I will go into detail later.
~Lou
