Current Versions of Plugins, and direct links....
Sun Sep 02, 2012 10:29 am
bschollnick2 offline
This is a shortcut to the Plugins that I have created....
(This post is a sticky, to prevent it from being lost in other postings...)
[*]v1.00 - Released 12/04/2013 v6+ Ready, and Adds Scheduling Functionality Download from Here[/list][/list]
  • Mountain Lion Notifications
  • Allow Indigo to use 10.8+'s Notification services.
  • Survey
  • Quickly scan your Indigo devices to find non-responsive devices.
  • What is the Survey Plugin?The Survey plugin is primarily used for helping diagnose or identifying issues with the Indigo device network. The plugin will send a “ping” out to each device on the network and track how long it takes the device to respond. These metrics can help identify devices that are slow to respond, or responding erratically.
  • More Information http://forums.indigodomo.com/viewtopic.php?f=33&t=12186
  • UPS & Battery Monitor
  • Allow Indigo to monitor any UPS that will work with the Mac OSes Energy Saver System Preference Panel.
  • Weather Conditions
  • Indigo can become your own home Weather Forecasting service.
    • At this point, Weather Conditions is effectively retired. It needs a rewrite to add State support, and Google has shut down their weather service, leaving just Weather Underground. So at this point, I will rewrite it in the future, but the current version is retired.
In addition, there are two programming API's that I have worked on.
These are not affiliated with Perceptive Automation, but I feel that other programmers should not have to re-invent the wheel:
  • Indigo Restful API
  • The Indigo Restful API, is a python wrapper that makes it easier to control Indigo via the python (through the IWS interface).
  • For example:
       Indigo_server = indigo_restful_api.Indigo_Restful_Server ()
       Indigo_server.set_server (r"http://192.168.1.110:8080" )
    #   Indigo_server.set_server_authentication ( "test", "test")
        device_list = Indigo_server.get_device_list ()
        for device in device_list:
           device_information = Indigo_server.get_device_by_name ( device )
           name =  device_information["name"]
                    print name
  • Version Check
  • Version Check will poll http://www.indigo-plugins.com, and check the data base to see if there is a newer version of the plugin. If so, it will notify the user to upgrade to the newest version.
  • Version Check is retired. The concept is sound, but the web front end doesn't scale properly.
for v5 - http://bit.ly/T6WBKu
Tue Sep 04, 2012 3:10 pm
DU Lou offline
Re: Current Versions of Plugins, and direct links....
Ben,
Would you like all comments and feedback regarding Switchboard (Formerly known as Indigo Security Script) to be posted in that thread, or start a new topic?
Lou
Mon Sep 10, 2012 6:47 pm
DU Lou wrote:
Ben,
Sorry about the delay Lou. I've been playing around with some ideas... For now, jump over to here...
General Switchboard feedback
