CraigM wrote:
- Code: Select all
Jun 12, 2012 12:06:02 PM
Enabling plugin "Thermostat Enhancement Add-On 1.01"
Starting plugin "Thermostat Enhancement Add-On 1.01" (pid 2345)
Plugin "Thermostat Enhancement Add-On" connected
Plugin "Thermostat Enhancement Add-On 1.01" started
Thermostat Enhancement Add-On Debug Version Check Server reports 0.90 is available.
Thermostat Enhancement Add-On Debug Mode is activated. (Only use if testing...)
Jun 12, 2012 12:07:12 PM
SQL Logger Error exception trying to insert row into table device_history_201576345 ("HVAC [thermostat enhancement plug-in]") -- unable to modify table
SQL Logger Error no such table: device_history_201576345
SQL Logger Error INSERT INTO device_history_201576345 (belowminimiumtemp, currentcoolingsetpoint, currentheatsetpoint, currenttemperature, lastupdated, maximumtempexceeded, acdailyruntime, aclastoff, aclaston, aclastruntime, acmonthlyruntime, acweeklyruntime, acyearlyruntime, fandailyruntime, fanlastoff, fanlaston, fanlastruntime, fanmonthlyruntime, fanweeklyruntime, fanyearlyruntime, heatingdailyruntime, heatinglastoff, heatinglaston, heatinglastruntime, heatingmonthlyruntime, heatingweeklyruntime, heatingyearlyruntime) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s);
I need to understand this more clearly, and I believe the only way that is going to happen is to examine your Indigo database.
Please zip your database, and send me a copy of it to Benjamin AT schollnick dot net.
I need to see the details about your configuration to solve this...
