Indigo Weather Conditions
Mon May 30, 2011 7:35 am
bschollnick2 offline
What is Indigo Weather Conditions?
Quite Simply, it's a built-in Weather tool for Indigo. While it is similar to the NOAA script, it doesn't simply populate the variables in Indigo. It is designed for Indigo v5, and it does so much more...
First, it has an honest to goodness, User Interface. Second, it will also product a web page that give you the current Weather Conditions, as well as a Weather forecast.
Installation
1) Download the ZIP file, and unarchive it.
Version 0.90 -- http://dl.dropbox.com/u/241415/Indigo%2 ... review.zip
2) Open the folder, and take the Weather-Conditions.indigoPlugin and place it into
/Library/Application Support/Perceptive Automation/Indigo 5/Plugins
3) From the same folder, take the Weather-Conditions folder, and place it into:
/Plugins/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/Plugins
4) Restart the Indigo 5 Server
5) After the Indigo server restarts, it will immediately open a dialog window, asking you to the set the default settings for the Weather Conditions plugin.
Note:
The User Interface is designed for multiple weather providers, but the results from each provider is different. At this point, I am only supporting Google Weather, due to the forecast. If there is demand, I will be extending it to support other providers.
The automatic refresh is not currently working. Please manually make a Schedule:
Name - (As you wish)
Time - Set to Every X hour Y minutes, as you desire. For example every 30 minutes...
Under Actions
Choose Plugin
Plugin - Weather Conditions
Action - Update Weather Information
When the Schedule API is finished, you will be able to remove this Schedule, and the Weather Conditions plugin will manage the Schedule automatically.
for v5 - http://bit.ly/T6WBKu
Tue May 31, 2011 10:26 am
Brandt offline
Re: Indigo Weather Conditions
Is it possible for this plugin to help with detecting rain in the last couple days or in the next couple days for use with preventing sprinkler irrigation?
Indigo 7 w/ Dual-Band 2413U PLM
macOS High Sierra 10.13.x
2011 iMac 3.4 GHz Intel Core i7
Tue May 31, 2011 10:52 am
Maybe indirectly? Via the humidity reading. But Google Weather, Yahoo Weather, and NOAA do not seem to have a direct rainfall reading, so I can't data scrape the information.
If you have any suggestions on where to get rain fall readings, please feel free to point me in that direction...
Tue May 31, 2011 11:15 am
Brandt offline
When I was using Heyu I wrote a bash script to check the rain using wunderground.
Tue May 31, 2011 11:37 am
I haven't had a chance to look at Wunderground. They do offer that for PWS stations, but Wunderground's offering seem to change were location. That makes it hard to make a standard output form... But with Cheetah templating, I can possibly work around it...
I'll see what I can do...
Thu Jun 02, 2011 3:23 pm
Brandt offline
I'm getting an error:
  Reloading plugin "Weather Conditions 0.90"
  Stopping plugin "Weather Conditions 0.90" (pid 206)
  Plugin "Weather Conditions" disconnected
  Starting plugin "Weather Conditions 0.90"
  Plugin "Weather Conditions" connected
  Plugin "Weather Conditions 0.90" started
  Weather Conditions              Weather Conditions Plugin Loaded...
  Weather Conditions              Weather Service Google Weather selected
  Weather Conditions              Update Frequency - 60 Minutes
  Weather Conditions              Location to check - 92692
  Weather Conditions              Retrieving Weather Condition Information
  Weather Conditions              Writing Data to Variables
  Weather Conditions Error        Error in plugin execution startup:
  File "plugin.py", line 87, in startup
  File "plugin.py", line 125, in fetch_Weather_information
  File "plugin.py", line 130, in run_weather_update
  File "plugin.py", line 117, in write_data_to_variables
<type 'exceptions.AttributeError'>: 'Plugin' object has no attribute 'current_conditions'
Thu Jun 02, 2011 8:27 pm
[/code]
Interesting...
Try upgrading to v0.95 (http://dl.dropbox.com/u/241415/Indigo%2 ... Plugin.zip).
1) Remove the old plugin.
2) Remove the Time/Date Schedule that you have created.
3) Install v0.95
4) Configure v0.95 via the Plugin Menu Configure option..
The Time/Date scheduling is now automatic...
Thu Jun 02, 2011 10:48 pm
Brandt offline
Can you automatically create a variable naming the city for the zip code given? Also a variable for last observation timestamp.
Sat Jun 04, 2011 3:53 pm
Yes, I can...
In the next couple of days, I will be releasing a new version of IWC.
The next version will add Weather Underground & Weather Underground Forecasting... The Weather Underground PWS support may be added later.... (Depending on demand...)
The automatic scheduler was added in v0.95 (released a few days ago)...
What else is desired?
Sat Jun 04, 2011 7:14 pm
Brandt offline
Well I hate to tie it into irrigation, but that's all I would need weather for at the moment....maybe be able to set a threshold for number of inches of precipitation allowed, or number of days since rain, or rain in the forecast before setting a wateringOK variable to true/false or something like that
Sun Jun 05, 2011 7:59 pm
bschollnick2 wrote:
Yes, I can...
I spoke slightly too soon. I have run into a big problem with Weather Underground Forecast support... The base settings are fine, but I am having an issue with Python XML decoding on the Weather Underground Forecast feed.
- Ben
Tue Jun 07, 2011 7:46 am
I have worked around the Weather Underground forecast issue, I expect within the next day or two, I will be releasing the next version...
Tue Jun 07, 2011 7:35 pm
Indigo Weather Conditions v0.98 Beta is released
Folks,
Weather-Conditions v0.98 beta is released. (Indigo v5 only)
http://dl.dropbox.com/u/241415/Indigo%20Weather%20Conditions/Weather-Conditions%20v098.zip
# Changes on the Drawingboard
# - Examine adding /Wunderground PWS to pywapi, so that we can capture rain fall
# - switch to device model, so that the states can be accessed & possibly multiple Weather Services at the same time
# - Add NOAA Weather service
# Changes
# v0.98 - Third Public Beta Release
# - Added Weather Underground Support
# - Added WeatherLastUpdated for Variables
# - Added WeatherLocation for Variables
# - Added Preference for Allowing Variable Export
# - If Set, the Variables will be Exported.
# - If Not Set, the Variables will be deleted (if present)..
# - Added Preferences code, that will reload the preferences if
# the user makes a change in the Preferences screen.
# v0.95 - Second Public Beta Release
# - Changed to use Internal Scheduling
# v0.90 - First Public Beta Release
Tue Jun 07, 2011 11:31 pm
Brandt offline
I got these errors:
This is because no weather service is defined by default when the plugin is first enabled:
  File "plugin.py", line 143, in startup
<type 'exceptions.UnboundLocalError'>: local variable 'weatherservice' referenced before assignment
  Weather Conditions              Undefined Weather Service Request
You should catch that, and/or make a default weather service.
The pickled_data file doesn't exist?
Jun 7, 2011 10:27:23 PM
  Weather Conditions              Preferences were updated, reloading Preferences...
  Reloading plugin "Weather Conditions 0.98"
  Stopping plugin "Weather Conditions 0.98" (pid 1340)
  Starting plugin "Weather Conditions 0.98"
  Plugin "Weather Conditions 0.98" started
  Weather Conditions              The Web page will be Orientated Horizontally
  Weather Conditions              The Weather information will be exported as Variables.
  Weather Conditions              Retrieving Weather Condition Information from Google Weather
  Weather Conditions Error        Error in plugin execution runConcurrentThread:
  File "plugin.py", line 240, in runConcurrentThread
  File "plugin.py", line 228, in run_weather_update
  File "plugin.py", line 169, in fetch_google_weather
<type 'exceptions.IOError'>: [Errno 13] Permission denied: '/library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/plugins/Weather-Conditions/pickled_data'
  Weather Conditions Error        plugin runConcurrentThread function returned or failed; will attempt again in 10 seconds
Wed Jun 08, 2011 4:06 am
pomprocker wrote:
I got these errors:
That's very weird... Since my understanding is that Indigo should display the configuration screen when it's installed... But that's easy enough to fix, open the configuration screen, and set the values... I will add logic for this for the next version..
Something is odd. The pickled_data is the data from the plugin being saved into the IWS weather-conditions folder. Since old style IWS can't communicate with the new plugin, I am currently forced to use this "bottled" to exchange information...
Try removing your weather-conditions IWS folder, and replacing it with the v098 IWS folder... I suspect permissions are wrong there? Did you possibly change the Weather-Conditions folder name?
What happens if you open a terminal window, and type the following:
ls -la /library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/plugins/Weather-Conditions/
- Benjamin
Users browsing this forum: No registered users and 18 guests
