Network Monitor?
Wed Jul 15, 2015 7:23 pm
bschollnick2 offline
Network Monitor?
Folks,
I am considering starting work on a plugin, which would add:
* Indigo Web - display of devices on the LAN, Open ports on the said devices (see image)
* And possibly the integration of Network device detection to Indigo
I have a basic demo, see the attached image.
Is there interest in this? If so, I am willing to work on it, but I certainly wouldn't mind help on it...
This plugin would require a copy of FING on the system, the main data source is from FING, but I getting the data from the session files that FING creates.
Additional possibilities here could be BlueTooth Device detection, and/or the incorporation of Find My iDevice support...
- Benjamin
for v5 - http://bit.ly/T6WBKu
Wed Jul 15, 2015 8:15 pm
Re: Network Monitor?
That's what fingscan is doing
it produces also:
Screen Shot 2015-07-16 at 12.15.15 AM.png (304.85 KiB) Viewed 2875 times
Wed Jul 15, 2015 11:20 pm
Also if you use FINGs output from port scans you need to reformat the output with:
f.open(xxx,"r")
fingOut = f.read()
jObject= json.loads( fingOut.replace(",},","},").replace("},]","}]").replace("':",'":').replace(":'",':"').replace("','",'","').replace("{'",'{"').replace("'}",'"}') )
FING uses ' instead of " and it has "," after the last element in {} and [] and it also uses single ' in texts. So a simple replace ' with " does not do the trick.
Users browsing this forum: No registered users and 21 guests
