BSchollnick's RESTful API
Sat Jun 21, 2014 2:34 pm
Just want to thank Benjamin for his Python API for sending commands to the remote Indigo server. (Not to be confused with Indigo's built in RESTful API for scripting within Indigo)
I was using Powershell fired from a custom keyboard shortcut to run one or two actions, but there was a good 5-6 second delay whilst Powershell initiated and connected.
Using Python, from the same shortcut, the execution is down to about 1 second.
BTW, I converted it to v3.4 using the 2to3 script which is included in \Tools\Scripts when you install Python 3.
The convertor missed two lines.
Change set_server to:
def   set_server (in_server_address):
      Stores the server address, for use by the API/Wrapper.
      Inputs:
         indigo_server - the full url of the server (ie http://127.0.0.1:8176)
      Output:
         None
   global server_address
   server_address = in_server_address[/quote]
and within set_server_authentication() it misses adding "urrlib.request." on the build_opener
[code]self.opener = urllib.request.build_opener( self.handler)
Peter
