Thermostat Enhancement Plugin
Sat Sep 01, 2012 4:05 pm
CraigM offline
Re: Thermostat Enhancement Plugin
I did this per instructions:
Install Instructions:
    Download the Thermostat Add-On
    Unzip the zip file
    Double click on the Thermostat.indigoplugin file.  Indigo should prompt to install or upgrade the plugin.
    Create a New Indigo Device
       Type is Plugin
       Plugin is Thermostat Enhancement Add-On
       Model is Thermostat Monitor
Sat Sep 01, 2012 4:48 pm
bschollnick2 offline
    Unzip the zip file
       Type is Plugin
What's the name of the new Thermostat Monitor device?
If you look at that device, you'll see in the state listings, the information regarding the time running, etc. Do you see any information in the states window?
- Ben
for v5 - http://bit.ly/T6WBKu
Sat Sep 01, 2012 5:09 pm
CraigM offline
HVAC [thermostat enhancement]
All zero's and two false's
Sat Sep 01, 2012 10:07 pm
Make sure debug logging is turned on, and see what happens around the status of the thermostat changes. You should see some debug messages when the thermostat values change.
Do you see any?
- Ben
Sun Sep 02, 2012 3:15 pm
CraigM offline
It was turned on by default at install
Do you see any?
All I see are HVAC temp changes in the log:
Sep 1, 2012 9:05:42 PM
  Received INSTEON                "HVAC Thermostat [house]" on (button 1)
  Received INSTEON                "HVAC Thermostat [house]" temperature changed to 83.0
Sep 1, 2012 9:10:10 PM
  Received INSTEON                "HVAC Thermostat [house]" temperature changed to 82.0
Just to be clear, this plugin doesn't rely on any other plugin's, devices, variables, SQLite config's, scripts...?
Just install, and it should auto detect my Venstar Insteon traffic?
I know I'm jumping the gun since I can't even get the plugin to work at all, but will this plugin work with 2 Venstars, as I plan to add another sometime soon? If yes, are the data totals added together, or is the data kept in separate DB's?
Sun Sep 02, 2012 8:31 pm
That shouldn't happen... Could you have previously installed the Thermostat Enhancement plugin? I'm wondering if the plugin has a bad configuration?
Do you see any?
Try turning your AC or heating on and then off.
You should see something like:
Sep 2, 2012 9:40:25 PM
Sent INSTEON "Furnace Link" turn all off
Received INSTEON "Furnace Link" off (button 1)
Thermostat Enhancement Add-On The ac System ran for 489 minutes (Hours: 8.0)
Received INSTEON "Furnace Link" mode changed to all off; fan always on
From a design stand point, yes, it's all self contained.
I need to sit down and rework parts of the code to better support multiple thermostats... (I don't have multiples)
But it should work...
The data is stored in the device states....
- Ben
Mon Sep 03, 2012 1:23 pm
CraigM offline
OK, I'm going to start over.
- disable plugin
- trash plugin from disabled folder
- delete device
- stop/start server
- quit/launch client
- reboot MAC
- fresh install 1.05 (double-click on plugin)
Picture 2.png (19.48 KiB) Viewed 8292 times
de-bug ON by default at install (see line 2012-09-03 11:41:34):
2012-09-03 11:41:34   Application   Installing and enabling plugin "Thermostat Enhancement Add-On" v1.05
2012-09-03 11:41:34   Application   Loading plugin "Thermostat Enhancement Add-On 1.05"
2012-09-03 11:41:34   Application   Starting plugin "Thermostat Enhancement Add-On 1.05" (pid 152)
2012-09-03 11:41:34   Application   Plugin "Thermostat Enhancement Add-On" connected
2012-09-03 11:41:34   Application   Plugin "Thermostat Enhancement Add-On 1.05" started
2012-09-03 11:41:34   Thermostat Enhancement Add-On Debug   Version Check Server reports 0.90 is available.
2012-09-03 11:41:34   Thermostat Enhancement Add-On   Debug Mode is activated.  (Only use if testing...)
2012-09-03 11:44:07   SQL Logger   creating table device_history_40218621 for "HVAC [thermo enhancement]"
Picture 3.png (9.05 KiB) Viewed 8292 times
- create device
Picture 4.png (42.23 KiB) Viewed 8292 times
- start/stop server
- cycle AC on/off
NO data in device window
NO data in event log
It would be helpful if others who are using this plugin could chime-in with their experience, so we could compare the hardware/software being used. It's hard to troubleshoot when only two people are the conversation
Indigo 5.1.5
Venstar T1800
Insteon adapter 2441v, rev2.4r, 95 (i2cs engine)
OS 10.5.8
bschollnick2, what are your specs, as per above?
Mon Sep 03, 2012 2:10 pm
- disable plugin
- delete device
- stop/start server
- reboot MAC
I'm sorry, but you haven't started from scratch. You need to delete the preferences for the plugin, and the devices.
- disable plugin
- delete device
- stop server
- Delete the thermostat preference files as below
- start server
To completely uninstall, you need to go into the /Library/Application Support/Indigo 5/Preferences/Plugins folder
and remove the com.indigoplugin.Thermostat_Addons.indiPref file.
If you see any other Thermostat indiPref files, you may want to move them to the desktop....
A reboot of the computer is overkill... But acceptable.
Hardware:
Indigo 5.1.4
Venstar T1800, w/Adapter Firmware 92 (i2)
OS 10.6.8
Mon Sep 03, 2012 4:16 pm
Yes, it would be. But time and time again, I have seen that until someone has an issue, it's rare for anyone to chime up regarding a plugin or add-on.
I have asked many times for feedback on Switchboard, Find My iDevices, etc, etc, and very rarely do I get any acknowledgement or feedback.
So, if it's one thing I would love to see from the Indigo community, is more engagement, including conversations and feedback from the users of the plugins...
Heck, I would love to know what the population is of Indigo users? Matt, and Jay? Can you give us some idea of how many people are using Indigo / Indigo Pro?
- Benjamin
Mon Sep 03, 2012 4:24 pm
We don't publicize user base size numbers, but the Indigo community is definitely not huge. It is a niche of a niche market: those folks wanting to do home automation, and that also own a Mac and are wanting to use it as the controller. For any given plugin you can multiply on another niche that want that particular feature/integration, so it would be a niche cubed.
It is definitely the case that folks don't typically turn to the forum unless they have a problem, which makes it difficult to get the type of feedback you want. Once people get something up, configured, and working, they aren't likely to come back to the forum for a while. There are, of course, the core group of us here that are more serious about the hobby. ;-)
Mon Sep 03, 2012 4:59 pm
CraigM offline
bschollnick2 wrote:
- disable plugin
- delete device
- stop/start server
- reboot MAC
- disable plugin
- delete device
- stop server
- start server
Hardware:
Indigo 5.1.4
OS 10.6.8
OK, did your above steps, and deleted the pref file: com.schollnick.indigoplugin.Thermostat_Addons.indiPref
The only change to report is that the install DID NOT default to de-bug mode ON this time. But still no data.
Above you state
Devices plural? Is this a typo, or are there suppose to be more than one device?
Mon Sep 03, 2012 5:21 pm
CraigM offline
matt (support) wrote:
...It is definitely the case that folks don't typically turn to the forum unless they have a problem, which makes it difficult to get the type of feedback you want. Once people get something up, configured, and working, they aren't likely to come back to the forum for a while. There are, of course, the core group of us here that are more serious about the hobby. ;-)
Agreed, but I personally feel that if you are going to TAKE for free a fellow user's plugin that they have spent much time and money developing you should be obligated to subscribe to their master topic and contribute back to the developer with testing or comments when needed.
If everyone just TAKES, users will stop developing or updating their work. That wouldn't benefit any Indigo user. To all the plugin developers out there, many of us appreciate and rely on your work. THANK YOU.
But thats just me :wink:
Mon Sep 03, 2012 5:23 pm
Agreed totally. Nobody appreciates all these great plugins more than Jay and myself. Thanks plugin developers!
Mon Sep 03, 2012 6:00 pm
Very True.
Your relatively recent newsletter is a good step forward, but more outreach programs like that would be excellent move forward.
But this chain (user base) should be moved to the general forum.... But still, would it be worth having the newsletter every 2-4 months? Even if it just highlights some new features, and a 3rd party plugin?
- Benjamin
Mon Sep 03, 2012 6:06 pm
Oh, definitely. We'd like to have the newsletter more frequently. Just hard to find time to get it put together between working on everything else. We are overdue one right now as a matter of fact...
Page 5 of 10 1, 2, 3, 4, 5, 6, 7, 8 ... 10
