DU Lou wrote:Awesome...
v.72 has enabled me to implement a scenario that I have been wanting to try for about 4 months now!
I'm always interested in hearing how Switchboard has helped.... How about giving us some details?
- Ben
bschollnick2 wrote:DU Lou wrote:Awesome...
- Ben
jay (support) wrote:Without any plugins, you could just create ON triggers for each of the 3 lights in the bathroom which turns on the kpl button on, right?
bschollnick2 wrote:jay (support) wrote:Without any plugins, you could just create ON triggers for each of the 3 lights in the bathroom which turns on the kpl button on, right?
With switchboard, that's easy as well.
The issue, I see, is the trigger that is set to turn on from the KPL 3 being turned on.
I was thinking to have the secondary controllers, set a variable, and then have the main controller trigger, check for the variable... and not "fire" off, if the variable is set... And then have the variable reset back to false...
But it's a little bit more complex then this... I think I have an idea, but I need to think about it a bit more...
jay (support) wrote:I'm not sure I'm following - how is your trigger defined that's firing when the button is pressed or turned on via Indigo? I think I'd be using a "INSTEON Command Received" trigger to fire the scene - then you can turn on/off the LED at will via Indigo without the trigger firing...
jay (support) wrote:Yep - switch that first picture from a "Device State Changed" trigger to an "INSTEON Command Received" trigger and select the correct button. Then it will only fire when you actually press the button and it turns ON. It won't fire when you turn it on via the action in the last picture.
Sep 5, 2012 6:40:05 PM
Sent INSTEON "Lava Lamp" on
Switchboard Debug state change list for "Lava Lamp": [(u'onOffState', True)]
Switchboard Debug Device (Lava Lamp) is in Monitored Group 'Bedroom Group'
Switchboard Debug state change list for "Bedroom Group": [(u'Triggered_In_Group', u',Lava Lamp')]
Switchboard Debug state change list for "Bedroom Group": [(u'Triggered_In_Group', u'Lava Lamp')]
Switchboard Debug state change list for "Bedroom Group": [(u'Number_Triggered_Devices', 2)]
Switchboard Debug state change list for "Bedroom Group": [(u'Devices_Triggered', True)]
Switchboard Debug no state change for "Bedroom Group" (ignoring update)
DU Lou wrote:Hi Ben,
Two other items I noticed for your attention:
1) It appears when any single device is turned on the monitored device group will actually show 2 devices triggered:
- Code: Select all
This does not affect me since at the moment I really only care about 'Number of Devices Currently on or triggered = 0 or >0
2) Not sure if this is by design but I wanted to point out the following:
I have created Monitored Device Group A & B
It appears that if I have added Device X to both groups only one group (A for example) will reflect any updates. Once again this isn't a work stoppage since I can conditionally account for devices in both groups. However, moving forward, if possible, it would be nice to have Device X monitored in both Groups A & B. Let me know if you need further clarification on this.
bschollnick2 wrote:DU Lou wrote:1) It appears when any single device is turned on the monitored device group will actually show 2 devices triggered:
- Code: Select all
bschollnick2 wrote:bschollnick2 wrote:DU Lou wrote:1) It appears when any single device is turned on the monitored device group will actually show 2 devices triggered:
- Code: Select all
I can't seem to duplicate this. Can you try this without debugging active, and make sure it's consistent... ?
Are you running v0.72?
Hmmm... I understand, but I'm not sure that it's anything that I will be able to change soon. The one underlying assumption in Switchboard, is that the device is in a single Monitored group.
