"is not between" condition
support wrote:I believe Jay was suggesting one could use the Has any change trigger with a conditional that then checks the range (there are conditionals for between/not between testing). Then it could all be done with a single Trigger. We should probably add triggers for range checking though to make it simpler.
jay wrote:One trigger with an "is not between" condition would work as well. Just saying...
If temperature is greater than max_heat
OR
If temperature is less than min_heat
if temperature is not between min_heat and max_heat
support wrote:But I do not see how
- Code: Select all
OR
is not identical to:
- Code: Select all
support wrote:That definitely looks like a bug. Is it reproducible? Does it always happen? Does restarting the Indigo client help?
support wrote:Which is exactly why I asked you to help debug into what is going wrong above:support wrote:That definitely looks like a bug. Is it reproducible? Does it always happen? Does restarting the Indigo client help?
CraigM wrote:Just upgraded from v4pro to 5.12pro
Could someone please point me to the v5 Venstar Thermostat Usage Monitor download.
The User Contrib Lib only show v4
Schollnick.com talks about a v5, with the newest version v1.01. Is 1.01 the Indigo v5 download? Same file names that are in my v4 folder.
I downloaded it, restarted server, but nothing shows up in a browser like it used to at http://xxx.xxx.x.x:8176/
bschollnick2 wrote:CraigM wrote:Just upgraded from v4pro to 5.12pro
https://dl.dropbox.com/u/241415/Thermos ... 0v1.00.zip
Should be the latest...
I've received very little feedback from the v5 plugin release.... So, please feel free to drop me a line...
---- I added this below ----
The reason the v5 plugin is has a version 1 number, is because it's a complete rewrite, with significantly better features, then the original Applescript attachment script...
So, the Applescript version is considered (to me) to be a totally different application...
