Page 2 of 3
Re: did anyone have their icloud password compromised?
Posted:
Fri Sep 26, 2014 3:59 pm
by kw123
guess I found it, for the other "dummies":
in itunes, connect your iPad , go to Summary, toggle through ECID, Product type , serial number, UDID, just click on the last row just right of the iPad image,
then type the UDID in to UDID fields (all of them ) into __init__.py in directory
/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/find-my-iDevices.indigoplugin/Contents/Server Plugin/findmyiphone
as well as IOS version # and iPad type
Posted:
Fri Sep 26, 2014 5:29 pm
by kw123
This little script will modify the __init__.py file to change the UDID .. etc parameters .
first stop findMyIdevice plugin
copy this code into an action group script.
check the path to the indigo server files (version number) and
change the UDID productType and osVersion to your setting
click on run.
- Code: Select all
# -*- coding: utf-8 -*-
#this script will put your information into " __init__.py" to findMyIphone work without send emails every 5 minutes...
theNew_deviceUDID="xFc1cAcCcccccckljas;klfjaslf" # put your UDID here
theNew_productType="iPad4,4" # put your ipdad version here
theNew_osVersion="7.1.2" # put your os version here
# check the file path to the plugin (ie indigo version)
filePath='/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/find-my-iDevices.indigoplugin/Contents/Server Plugin/findmyiphone'
fileName='__init__.py'
fileName2='xxinit__.py' # this is the output file, if ok rename to __init__.py in finder or just name it the same as fileName to overwrite in place
f =open(filePath+'/'+fileName,"r")
theLines =[]
for lines in f:
theLines.append(lines)
f.close
# now write out and replace the changed strings
f =open(filePath+'/'+fileName2,"w")
nLines = len(theLines)
for nLine in range(nLines):
nextLine=theLines[nLine]
if nextLine.find("deviceUDID")>-1:
theParts= nextLine.split('":"')
nextLine =theParts[0]+'":"'+theNew_deviceUDID+'",\n'
if nextLine.find("productType")>-1:
nextLine =theParts[0]+'":"'+theNew_productType+'",\n'
if nextLine.find("osVersion")>-1:
nextLine =theParts[0]+'":"'+theNew_osVersion+'",\n'
f.write(nextLine)
f.close
Posted:
Sat Sep 27, 2014 6:49 am
by maslett
I was previously determining the home/away status of multiple family members. How do you enter the information for multiple iPhones?
Posted:
Sat Sep 27, 2014 7:50 am
by kw123
This is not the info if the iPhone to be tracked but a device that is requesting the info
Posted:
Sat Sep 27, 2014 10:00 am
by maslett
But since each iPhone (in my case) has a separate iCloud account wouldn't you need both to match else you'll be logging into an account to an iCloud account with an iPhone that may not match. Maybe I am missing something.
Posted:
Sat Sep 27, 2014 10:10 am
by kw123
Don't know how that would work. The deep Apple experts might want to chime in here. May be you just try it out. See it it works. You give the target id in the device config. The init file does show any info of the target device as I see it.
Posted:
Sun Sep 28, 2014 2:58 am
by macpro
Glad I found this topic. Had been wondering for a couple of days what the hack was going on with all those e-mails.
Posted:
Mon Sep 29, 2014 8:50 am
by eme jota ce
macpro wrote:Glad I found this topic. Had been wondering for a couple of days what the hack was going on with all those e-mails.
Same here. Thanks for posting and discussing. Had the same experience, but assumed it was an attempted hack.
Posted:
Mon Sep 29, 2014 4:12 pm
by bschollnick2
eme jota ce wrote:macpro wrote:Glad I found this topic. Had been wondering for a couple of days what the hack was going on with all those e-mails.
I'm thankful that folks have identified this method to prevent the emails. I haven't seen anything along this line in the Github discussions, so it's surprising, but it makes perfect sense.
- Ben
Posted:
Mon Sep 29, 2014 10:25 pm
by macpro
Well... the method doesn't work for me. We're still getting the mails, but at least we know who's sending them.
Posted:
Tue Sep 30, 2014 1:39 am
by kw123
do you have multiple apple accounts?
What works:
use an ipad account that uses the same apple account as the iPhone and us the credentials of the ipad.
make sure you enter the data correctly end and restart FMID
Posted:
Tue Sep 30, 2014 9:08 am
by five337
I'm also getting the emails again. I'm using an iPad 2,2 that is listed as a trusted device on the account that FMi is checking.
If I change the version number to 8.0.0 or 8.0.2 FMi shows that it logs on, but can't get the device information.
When I change the version to 7.2.0 or below - Apple sends the device IDs and location data, then pops out an email to me.
I have 2 step authentication on my devices - maybe that has something to do with it ?
Posted:
Wed Oct 01, 2014 12:47 pm
by macpro
@Karl: I used the script that you made and filled it with data from my iPad3,3.
Two AppleID's are being used. One ID for my iPhone and another ID for my wife's iPhone.
The iPad uses my AppleID, but the iPad is not tracked with FMi. Only the iPhones are and FMi has no troubles finding their locations.
Posted:
Wed Oct 01, 2014 1:46 pm
by kw123
so it works?
Posted:
Wed Oct 01, 2014 1:59 pm
by macpro
Not for me. I still get the mails.
