MQTT Broker
Thu Feb 29, 2024 11:12 am
MarcoGT offline
Re: MQTT Broker
Yes you can use Eclipse Mosquitto but I think it is only via Docker (I had it on my father’s setup), otherwise you can install it via brew (this is my choice), and it works fine since yesterday now, no restart necessary.
Thu Feb 29, 2024 12:49 pm
siclark offline
Re: MQTT Broker
Yes I did mine via homebrew too and unless you have reason for docker brew is easiest way for it to just work on you indigo server Mac.
Thu Feb 29, 2024 1:42 pm
SMUSEBY offline
Re: MQTT Broker
thank you both.
Mosquitto is now installed on my computer.
How do I point Indigo to this broker?
Thu Feb 29, 2024 1:48 pm
Re: MQTT Broker
If it's installed on the same system as Indigo (and the MQTT Broker plugin), then just disable the Broker plugin and restart Mosquitto. They're both going to use the same port.
You will need to edit the Mosquitto config file and make sure it's using the default port and to set a user/password.
Thu Feb 29, 2024 6:53 pm
SMUSEBY offline
Re: MQTT Broker
From terminal,
bSrvr1911:~ RSS$ brew services start mosquitto
Service `mosquitto` already started, use `brew services restart mosquitto` to restart.
bSrvr1911:~ RSS$
and it is listed as a process in the Activity Monitor, but it is not in the "Application" folder. I'm afraid I have no idea how to configure it? Is the default port 1883?
Sat Mar 02, 2024 1:19 am
siclark offline
Re: MQTT Broker
Yes that’s the default port. Download Mqtt explorer app or similar on the Mac and you can view the server and messages easily.
