Minor? Error in MQTT Shims
Mon Oct 24, 2022 8:59 am
berkinet offline
I have a Shim defined as a:
MQTT On/Off Sensor device
State value is in the payload fields and is a json boolean
Sensor Type is Power On/Off
Everything works, except, on each state update the plugin throws
state key onOffState not defined (ignoring update request)
Probably an if missing somewhere, because the actual device state in the State column updates properly.
And, FWIW, I had the same problem as reported by roquej, triggers would not fire. I finally deleted all MQTT devices, and the plugins, restarted Indigo, re-installed the plugins and devices,. and it started working. Odd.
BTW, thanks for the plugins, I am still trying to wrap my head around MQTT, especially returning messages back to the actual real world device. But, it looks like a pretty neat way to avoid custom plugins. At least in some cases. For example, my application is to observe, and possibly control a wireless sprinkler system from LinkTap.
Mon Oct 24, 2022 9:08 am
Re: Minor? Error in MQTT Shims
Can you run debug logging and capture the log entries when that message is received? And create a GitHub issue for it? Also include the device template (menu command).
Mon Oct 24, 2022 9:19 am
berkinet offline
Done.
Mon Oct 24, 2022 9:30 am
Mon Oct 24, 2022 9:33 am
One more thing - please add the Indigo device details for that Shim device to the issue. (Right click on device in Indigo list)
Mon Oct 24, 2022 12:12 pm
berkinet offline
And, done.
