Variables with special letters
Thu Feb 18, 2021 3:22 pm
tazswe offline
I’m playing around with a weather forecast in Node Red. I have transformed the time to what part of the day it is, evening, night, morning and so on.
I use the Mqttconnector plugin and it normally works without any problems.
It haven’t been any problem as long as I don’t use any of our special letters like an a or o with two dots. As soon as I use one of these special letters the variable refuse to update and will keep the previous value.
I use the variables to make announcements.
I have enclosed a picture, have a look at time1-5.
Mqtt Explorer is updating correctly.
Skickat från min iPad med Tapatalk
Thu Feb 18, 2021 3:42 pm
Re: Variables with special letters
How exactly are you getting the MQTT messages from Node-Red into the Indigo variables?
Thu Feb 18, 2021 3:55 pm
If you're using the Device/Variable Control panel of the Connector config dialog, what's the exact content of the "Command Topic" for variables?
Also, turn on debug logging and attempt to set those variables again. I need the log lines that have "Variable command match" in them.
Thu Feb 18, 2021 5:21 pm
tazswe offline
Tried to debug messages and didn’t get any error but the two with special letters didn’t trigger or gave any response. So at this point we are missing time2 and time4.
Thu Feb 18, 2021 5:25 pm
What are those triggers doing? Screen shot is ok.
In the future, please don't post screen shots of the logs. Copy and paste the text.
Thu Feb 18, 2021 5:27 pm
I don't see in the log you posted that you ever received time2 or time4.
Thu Feb 18, 2021 5:30 pm
tazswe offline
I have made one trigger for each variable like this
The trigger for time1 locks like this
I have also a components match trigger
And finally topic subscriptions on my MQTT server.
Thu Feb 18, 2021 5:34 pm
tazswe offline
Debugging message looks like this:
MQTT Connector Debug RPI Mosquitto: Message received: Node Red/weatherforecast/time1, payload: Vid midnatt
MQTT Connector Debug RPI Mosquitto: Message received: Node Red/weatherforecast/time3, payload: Vid lunchtid
MQTT Connector Debug RPI Mosquitto: Message received: Node Red/weatherforecast/time5, payload: Vid midnatt
Also tried critical messages and warning messages but don’t get anything.
Thu Feb 18, 2021 5:36 pm
Well, that's saying that your Node-red system isn't publishing time2 or time4. The Connector plugin never gets them. Are you sure those are showing up in MQTT Explorer?
Thu Feb 18, 2021 5:37 pm
Is that topic component trigger actually doing anything? There's no point it having it if the topic string triggers are doing the work.
I'm going to need to try to recreate this. I need the exact topics and payloads that are working and not working. As text here that I can copy and paste into my system.
Thu Feb 18, 2021 5:41 pm
tazswe offline
I am sure that they are showing up in Explorer.
Had the same problem with the weather variables when I had them in Swedish and when I changed them to English the problem disappeared.
I have identical settings for the local buss timetable, but the destinations don’t have any special letters so that is working.
Thu Feb 18, 2021 5:44 pm
tazswe offline
Do you think that I shall remove the component trigger?
Thu Feb 18, 2021 5:47 pm
tazswe offline
Is there a free mqtt server that I can send the payloads to?
Thu Feb 18, 2021 6:01 pm
tazswe offline
This is from my function in Node Red.
My comments and explanations what letter I causing the problem.
Tid = msg.payload;
if (Tid == "15:00")
return {payload:"Under Eftermiddagen"}; OK
Tid2 = msg.payload;
if (Tid2 == "18:00")
return {payload:"Vid Tidig kväll"}; Not working contains letter ä
Tid3 = msg.payload;
if (Tid3 == "21:00")
return {payload:"Under Kvällen"}; Not working contains letter ä
Tid4 = msg.payload;
if (Tid4 == "00:00")
return {payload:"Vid midnatt"}; OK
Tid5 = msg.payload;
if (Tid5 == "03:00")
return {payload:"Under natten"}; OK
Tid6 = msg.payload;
if (Tid6 == "06:00")
return {payload:"På morgonen"}; Not working contains letter å
Tid7 = msg.payload;
if (Tid7 == "09:00")
return {payload:"Under förmiddagen"}; Not working contains letter ö
Tid8 = msg.payload;
if (Tid8 == "12:00")
return {payload:"Vid lunchtid"}; OK
Thu Feb 18, 2021 7:01 pm
If there's no actions attached, then it's not doing anything except taking up time.
