Is the "trigger" fixed in 0.4.4?
Wed Dec 30, 2020 12:47 pm
CliveS offline
Not sure if it is me but I cannot get the trigger to fire and my SP600 power plug turns on and off at the physical plug when I click the Turn On and Turn Off buttons but the State stays at On in the GUI.
Same happens with my Aqara 2 Gang Wireless Switch which has been opening and closing the garage door reliably for months but no longer.
   MQTT Shims Debug                received notification of MQTT message type shellies from Indigo MQTT Server
   MQTT Shims Debug                SP600: publish_topic: zigbee2mqtt/SP600/set -> {"state": "ON"}
   MQTT Shims Debug                SP600: publish_topic: zigbee2mqtt/SP600/set -> {"state": "OFF"}
CliveS
Wed Dec 30, 2020 3:04 pm
Re: Is the "trigger" fixed in 0.4.4?
I'm missing the context here. What IoT devices do you have, what MQTT messages are they publishing or receiving, and what's the content of those messages?
Don't assume I remember anything you've posted previously. ;)
Wed Dec 30, 2020 5:01 pm
CliveS offline
I think it is due to the problem of the extra " " being inserted.
I trigger an action
if 'click' in dev.states:  # State "click" of "Aqara 2 Gang Wireless Switch"
   devSwitch = dev.states["click"]
   import time
   indigo.server.log(str(devSwitch) + " button Press")
   if devSwitch == "left":
      indigo.actionGroup.execute(actGarageOpen)
      indigo.server.log("Left Single Press")
      time.sleep(.5)
      indigo.server.log(" ")
which in the log gave
2020-12-24 11:48:30.333   Trigger   Garage Door Open-Close By Aqara
2020-12-24 11:48:30.742   Script    Script Triggered
2020-12-24 11:48:30.744   Script   left button Press
2020-12-24 11:48:30.744   Action Group   Garage Door Left Open
but now errors due to the added "left" instead of left
2020-12-30 22:46:38.435   Trigger   Garage Door Open-Close By Aqara
2020-12-30 22:46:38.858   Script    Script Triggered
2020-12-30 22:46:38.858   Script   "left" button Press
2020-12-30 22:46:38.859   Script Error   Aqara_Wireless_Switch.py: global name 'left' is not defined
So I will wait for the revamp of the MQTT Shims.
CliveS
Wed Dec 30, 2020 5:42 pm
Change this line:
to
   devSwitch = dev.states["click"].strip('\"')
Wed Dec 30, 2020 5:58 pm
CliveS offline
Thank you, now opening and closing garage door
:D
CliveS
