Error message from MQTT Shims following CC2531 reflash
Sun Dec 27, 2020 8:05 am
I have had to reflash my CC2531 as it wouldn't connect to my iMac. It now does. :D
I am now getting these error messages from MQTT Shims:
   MQTT Shims Debug                Hue Motion 4 - Illuminance: processMessages: '##hue_motion_4##' zigbee2mqtt/Hue_motion_4 -> {"battery":100,"illuminance":18190,"illuminance_lux":66,"last_seen":"2020-12-27T13:40:02+00:00","linkquality":15,"motion_sensitivity":"high","occupancy":true,"occupancy_timeout":0,"temperature":16.44,"update":{"state":"idle"},"update_available":false}
   MQTT Shims Debug                Hue Motion 4 - Illuminance: shimValueSensor, key = illuminance_lux, data = {u'linkquality': 15, u'illuminance_lux': 66, u'update_available': False, u'motion_sensitivity': u'high', u'temperature': 16.44, u'battery': 100, u'update': {u'state': u'idle'}, u'occupancy': True, u'illuminance': 18190, u'occupancy_timeout': 0, u'last_seen': u'2020-12-27T13:40:02+00:00'}, value = 66
   MQTT Shims Debug                Hue Motion 4 - Illuminance: Updating state to 66.0
[color=#FF0000]   MQTT Shims Error                Error in plugin execution runConcurrentThread:
  File "plugin.py", line 107, in runConcurrentThread
  File "plugin.py", line 132, in processMessages
  File "plugin.py", line 541, in update
TypeError: state value type must be bool, int, real, or string
   MQTT Shims Error                plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
[/color]   MQTT Shims Debug                Hue Motion 5 - Illuminance: processMessages: '##hue_motion_5##' zigbee2mqtt/Hue_motion_5 -> {"battery":100,"illuminance":21816,"illuminance_lux":152,"last_seen":"2020-12-27T13:36:45+00:00","linkquality":44,"occupancy":true,"temperature":21,"update_available":false}
   MQTT Shims Debug                Hue Motion 5 - Illuminance: shimValueSensor, key = illuminance_lux, data = {u'linkquality': 44, u'illuminance_lux': 152, u'update_available': False, u'temperature': 21, u'battery': 100, u'occupancy': True, u'illuminance': 21816, u'last_seen': u'2020-12-27T13:36:45+00:00'}, value = 152
   MQTT Shims Debug                Hue Motion 5 - Illuminance: Updating state to 152.0
   MQTT Shims Debug                Hue Motion 5 - Temperature: processMessages: '##hue_motion_5##' zigbee2mqtt/Hue_motion_5 -> {"battery":100,"illuminance":21816,"illuminance_lux":152,"last_seen":"2020-12-27T13:36:45+00:00","linkquality":44,"occupancy":true,"temperature":21,"update_available":false}
   MQTT Shims Debug                Hue Motion 5 - Temperature: shimValueSensor, key = temperature, data = {u'linkquality': 44, u'illuminance_lux': 152, u'update_available': False, u'temperature': 21, u'battery': 100, u'occupancy': True, u'illuminance': 21816, u'last_seen': u'2020-12-27T13:36:45+00:00'}, value = 21
   MQTT Shims Debug                Hue Motion 5 - Temperature: Updating state to 21.0
   MQTT Shims Debug                MOTION - Bathroom - SENSOR: processMessages: '##hue_motion_5##' zigbee2mqtt/Hue_motion_5 -> {"battery":100,"illuminance":21816,"illuminance_lux":152,"last_seen":"2020-12-27T13:36:45+00:00","linkquality":44,"occupancy":true,"temperature":21,"update_available":false}
   MQTT Shims Debug                MOTION - Bathroom - SENSOR: shimOnOffSensor, state_key = occupancy, data = {u'linkquality': 44, u'illuminance_lux': 152, u'update_available': False, u'temperature': 21, u'battery': 100, u'occupancy': True, u'illuminance': 21816, u'last_seen': u'2020-12-27T13:36:45+00:00'}, value = True
   MQTT Shims Debug                MOTION - Bathroom - SENSOR: Updating state to True
   MQTT Shims Debug                Hue Motion 1 - Illuminance: processMessages: '##hue_motion_1##' zigbee2mqtt/Hue_motion_1 -> {"battery":87.5,"illuminance":13279,"illuminance_lux":21,"last_seen":"2020-12-27T13:40:11+00:00","linkquality":105,"motion_sensitivity":"high","occupancy":true,"occupancy_timeout":0,"temperature":22.47,"update":{"state":"idle"},"update_available":false}
   MQTT Shims Debug                Hue Motion 1 - Illuminance: shimValueSensor, key = illuminance_lux, data = {u'linkquality': 105, u'illuminance_lux': 21, u'update_available': False, u'motion_sensitivity': u'high', u'temperature': 22.47, u'battery': 87.5, u'update': {u'state': u'idle'}, u'occupancy': True, u'illuminance': 13279, u'occupancy_timeout': 0, u'last_seen': u'2020-12-27T13:40:11+00:00'}, value = 21
   MQTT Shims Debug                Hue Motion 1 - Illuminance: Updating state to 21.0
[/color]
It appears to be with Hue Motion sensors - other devices, when they get a look in, appear to be working OK. :)
Any suggestions on what I can try or further info needed?
Sun Dec 27, 2020 8:44 am
Re: Error message from MQTT Shims following CC2531 reflash
Which version plugin you running? Make sure you're running the latest.
Sun Dec 27, 2020 10:01 am
I was running an earlier version - Oddly, it wasn't showing up in the menu list as an updated plugin (Indigo 7.5) - others are though. :?
Anyway, updated to V0.4.0 and I am still getting the same error - but there are a load of messages pending; about 138.
How do I flush the queue? :)
Sun Dec 27, 2020 10:26 am
Restarting the Connector plugin is the only way to empty the queue.
You might want to disable the trigger until you get this fixed.
What line number in 0.4.0 is the error now?
Sun Dec 27, 2020 10:32 am
File "plugin.py", line 115, in runConcurrentThread
File "plugin.py", line 139, in processMessages
File "plugin.py", line 742, in update
Sun Dec 27, 2020 10:38 am
Hmm. I need to see the Shim device definition. Either screenshot or template output.
Sun Dec 27, 2020 11:20 am
message_type: '##hue_motion_5##'
props:
SupportsBatteryLevel: true
SupportsSensorValue: true
battery_payload_key: battery
shimSensorPrecision: '0'
shimSensorSubtype: Luminance
state_dict_payload_key: .
state_location: payload
state_location_payload_key: illuminance_lux
state_location_payload_type: json
state_location_topic_field: '0'
uid_location: topic
uid_location_topic_field: '1'
trigger:
match_list: '["Match: zigbee2mqtt", "Match: Hue_motion_5"]'
queueMessage: true
type: shimValueSensor
Hopefully this is what you are looking for? :)
Sun Dec 27, 2020 11:28 am
Yeah, that'll do. I don't see anything obviously wrong, so I'm going to create a device per that definition and see what happens here.
Sun Dec 27, 2020 11:35 am
OK - Thanks for your help. :)
Sun Dec 27, 2020 12:31 pm
Ok, what's causing the error is this part of the payload:
I thought I had code in there to check for this situation. Need to look a little closer.
Sun Dec 27, 2020 12:52 pm
I had added code for that issue, but had forgotten to include it for all device types. Oops.
Try this pre-release: https://github.com/FlyingDiver/Indigo-S ... /tag/0.4.1
Sun Dec 27, 2020 12:59 pm
Installed new version. :)
Now getting a different error:
MQTT Shims Debug MOTION - Study - SENSOR 2: Updating state to True
File "plugin.py", line 626, in update
UnboundLocalError: local variable 'new_states' referenced before assignment
MQTT Connector Warning Queue for message type '##aqara_motion_1##' has 31 messages pending
MQTT Shims Debug received notification of MQTT message type ##aqara_motion_1## from Flying Diver MQTT
MQTT Connector Warning Queue for message type '##aqara_motion_1##' has 32 messages pending
Taking a break for supper now :)
Sun Dec 27, 2020 1:05 pm
Sun Dec 27, 2020 1:06 pm
I've got to go back and refactor this code so I don't have so many duplicate code blocks...
Sun Dec 27, 2020 1:46 pm
Installed 0.4.2 :)
Got this error:
MQTT Shims Debug MOTION - Kitchen - SENSOR 2: Updating state to True
File "plugin.py", line 632, in update
TypeError: argument of type 'type' is not iterable
