Processing encoded payload data
Thu Nov 23, 2023 5:38 am
Re: Processing encoded payload data
I think what's going on is that creating the Df5Decoder object each time is taking too long. I updated the plugin to cache an actual Decoder object, rather than the Class. Install:
https://github.com/FlyingDiver/Indigo-S ... g/2023.0.1
Then, change your decoder to this:
from ruuvi_decoders import Df5Decoder
class Ruuvi(object):
    def __init__(self, name):
        self.name = name
        self.decoder = Df5Decoder()
    def decode(self, payload):
        new_states = {}
        ruuvi_data = payload['data']
        ruuvi_data = ruuvi_data.split("FF9904")[1]
        new_states = self.decoder.decode_data(ruuvi_data)
        if len(new_states):
            return new_states
            return None
This caches the Df5Decoder object when the Decoder is loaded, rather than each time through.
Thu Nov 23, 2023 5:42 am
Also, your trigger is defined wrong. It should be:
Match:   ruuvi
Any:
There's no value used for an "Any" term. I should probably throw a warning when someone tries to do that. As it is, your trigger is firing for any MQTT message with two components in the topic.
Thu Nov 23, 2023 10:53 am
berkinet offline
Upgraded to shims v 2023.0.1, changed the Decoder, and revised the trigger config. Still get queueing messages after around a minute.
However, I have also added a Scheduled action to only enable the trigger for 3 seconds and one minute in interval, and that seems to have resolved the queue problem. I have also been in contact with Ruuvi and they say they will be implementing a throttle on message publishing frequency.
So, for my needs, this is now "working" for my needs. However, if you want further testing, I'd be glad to help.
Thu Nov 23, 2023 11:06 am
Hmm. It must really be flooding messages. I really don't think the processing of each message takes that long.
Thu Nov 23, 2023 11:12 am
berkinet offline
Enjoy your holiday. I, for one, am very thankful for your help and support.
