Sensor value and Battery Value for device as separate topics
Sun Dec 06, 2020 7:47 pm
Re: Sensor value and Battery Value for device as separate to
The End term is there to NOT match if there are still components of the topic that haven't been used yet. It's to keep a topic with extra terms after from matching on a partial topic.
Which you use it entirely up to you. I just put in a lot of tools to give you the most flexibility. OTOH, your best efficiency (least extra processing time) is when the message-type defines a specific sensor type that only matches one Shim definition. If you use less triggers, with a generic message-type, then ALL the Shim devices that use that message-type have to be called to see if the message matches (Unique ID).
In your case, since those are different Shim types, you should use different triggers with different message-types.
Thu Dec 10, 2020 8:50 am
Ramias offline
Here's another follow up question:
I have a whole bunch of these in my logs:
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 26 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 27 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 28 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 29 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 30 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 31 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 32 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 33 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 34 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 35 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 36 messages pending
Is this because I have a message that isn't matching on a shim? Any way I can see what the message(s) is/are?
Thu Dec 10, 2020 8:56 am
That mean you have a trigger queuing messages with the type "##RingAlarm##" that doesn't have a Shim using the message. So they're piling up waiting for some shim device to request them.
You need to disable that trigger until you have a Shim ready to use it.
Thu Dec 10, 2020 4:08 pm
Ramias offline
I was missing a Shim.
I now have 16 topics (devices) under /ring/accountGUID/alarm/#.
Logs show this ever 5 minutes:
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 11 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 12 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 13 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 14 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 15 messages pending
   MQTT Connector Warning          Queue for message type '##RingAlarm##' has 16 messages pending
Sometimes it is 15 messages. Could this just be a lag issue if all 16 topics update at once and the plugin queues them before the Shim can process them?
Good thing is the count has not been higher than 16 for the past several hours.
Thu Dec 10, 2020 4:11 pm
Yeah, that just means a slew came in at once and slowly get processed. I specifically designed the system to queue that way so that messages didn't get lost if a bunch of MQTT traffic came in faster than the inter-plugin system could process them.
Thu Dec 10, 2020 4:13 pm
It only shows the entry in the log when there's more than 10 messages in the queue.
Fri Dec 11, 2020 10:04 pm
Ramias offline
cool. I thought about changing line 942 to make it a debug event instead of a warning. But figured I may want the warning if they get super high. So I changed line 941 to 25 -- just a few higher than my current number of Shim devices.
Fri Dec 11, 2020 10:22 pm
Open an issue on GitHub and I'll make it configurable. ;)
