MQTT Plugins updated for Indigo 2022.1
Wed May 11, 2022 4:52 am
Both MQTT Connector and MQTT Shims plugins have been updated for Indigo 2022.1 and should be available in the plugin store.
In addition, the MQTT Broker plugin is new for Indigo 2022.1 and will be available in the store shortly. This plugin implements a simple MQTT broker and can be used instead of Mosquitto. This plugin is only suitable for use when all MQTT clients are on your local LAN, as there is no authentication enabled at this time. I do NOT recommend port-forwarding to this MQTT broker from outside your LAN. No configuration is necessary. It will use the default MQTT port unless overridden in the plugin config.
Mon Oct 10, 2022 12:15 pm
Venicenerd offline
Re: MQTT Plugins updated for Indigo 2022.1
Hi @FlyingDriver can this plugin be used as a replacement of HassBridge?
It seems that plugin is no longer maintained and I'm not sure if it will even till work with 2022.1?
