An MQTT config example to Newbies from a Newbie...
Fri Jul 02, 2021 5:42 am
autolog offline
Re: An MQTT config example to Newbies from a Newbie...
You have a comma after the 192 - is that your issue?
Fri Jul 02, 2021 5:47 am
Seeker offline
sorry, typo in post. settings seem correct.
Mon Apr 04, 2022 11:26 am
VincentS offline
Hi Thanks for this wonderful explanation.
On question though I have a simular setup where I use Tasmota sensors to monitor If my bed is occupied. All of this is working fine thanks to the shimms plugin. But one value I cannot get right and that is the online status as all the other values are sensor values in JSON and the online/offline status is just raw payload.
How do I het the payload of topic tele/bed_links/LWT into the state column
Kind regards,
Vincent
LWT State.png (318.46 KiB) Viewed 6412 times
Thu Apr 07, 2022 11:38 am
You'll probably need to create a second Shim device just for that state value. The complexity of trying to modify Shims to fold all that into one device is just not worth the effort.
Thu Apr 07, 2022 11:40 am
Well, I take that back. I did enable rolling all payloads from one base topic into a single device. It's called an "aggregate" device and it's configured in the Connector plugin.
Thu Apr 07, 2022 2:50 pm
VincentS offline
Thanks Joe, I'll play with that..
Fri May 20, 2022 1:18 am
Moved other user question to new thread.
