Started getting an error when I merged two devices
Sun Jun 02, 2019 7:42 am
norcoscia offline
On my sense I had dryer and dryer1 (or Dryer2 - I can't remember). On the sense control panel I merged those two dryers since I only have one. Then in indigo I deleted the extra dryer. Started to see this in the log every few seconds. Help :-)
PS. Restarting Sense plug-in does not fix..
   Sense Debug                     Active: 1220.26394893w
   Sense Debug                     Daily: 3.8793838kw
   Sense Debug                     CSV Output: 2019-06-02 06:33:18.983720,1220
   Sense Debug                     CREATED: Dryer
   Sense Error                     NameNotUniqueError
   Disabling plugin "Sense 1.0.4"
   Stopping plugin "Sense 1.0.4" (pid 68002)
   Sense Debug                     shutdown called
   Stopped plugin "Sense 1.0.4"
_______
Norm
Sun Jun 02, 2019 7:49 am
norcoscia offline
Re: Started getting an error when I merged two devices
Tossing out the sense csv file and having the plug-in restart and make a new csv did not help...
_______
Norm
Sun Jun 02, 2019 8:39 am
norcoscia offline
I disabled the plug-in and then deleted the sense plug-in dryer device. Restarted the plug-in and it created a new dryer device - that seems to have fixed it!
_______
Norm
Sun Jun 02, 2019 8:42 am
norcoscia offline
Spoke too soon - error is back and the newly created dryer drive is missing the power symbol ....
   Sense                           Debug logging enabled
   Sense Debug                     Rate limit is: 30
   Sense Debug                     Active: 2849.70836728w
   Sense Debug                     Daily: 5.697364kw
   Sense Debug                     CSV Output: 2019-06-02 07:39:48.065153,2849
_______
Norm
Sun Jun 02, 2019 8:44 am
norcoscia offline
Reloading the plug-in seems to have corrected the device and the error has stopped?
_______
Norm
Sun Jun 02, 2019 8:53 am
Did you delete (online) the dryer, and rename dryer2 to dryer?
NameNotUnique is trying to create the device because plugin doesn’t know about it - which means the Sense device id isn’t known to the plugin.
If you delete a device in Indigo (dryer2) it removes the id from its own list, so if you’d renamed dryer2 to dryer that would explain the situation.
(Renaming a device in Sense is handled ok in the plugin, I tested that, so this is only way I can think of causing this problem)
Sun Jun 02, 2019 9:31 am
norcoscia offline
It is working great now and to be honest I would not bet my life on exactly what I did (it was yesterday late) - but good info from you on how to handle it next time and how the plug-in works - Thanks
_______
Norm
