does roon b1353 work with the plugin?
Fri Nov 24, 2023 5:39 am
dtich offline
they've switched to server/client architecture with this build. don't want to update roon if it breaks the plugin. anyone try it yet, or have any info?
thx!
Fri Nov 24, 2023 6:32 am
Re: does roon b1353 work with the plugin?
Yes, it does. :)
You may have to update the Roon Core Port in the plugin configuration.
You can find the required port number in the Roon App by navigating to Settings > Display. The required port number is shown as part of the Web display URL.
You may need to reauthorise the extension in Roo n
Fri Nov 24, 2023 6:43 pm
dtich offline
oh--that doesn't sound so broken, if it just needs a tweak to the config. if that's true i'll do the update.
thanks jon~!
