Hue Lights - Free Philips Hue Plugin
Mon Nov 07, 2016 12:56 am
nsheldon offline
Re: Hue Lights - Free Philips Hue Plugin
Version 1.3.30 Posted
  • Fixed a bug in 1.3.29 that prevented Hue Lights from recognizing the 2nd generation LightStrips.
Sun Nov 13, 2016 1:17 am
nsheldon offline
Version 1.4.0 Posted
  • Added support for color picker in RGB and HSB color setting actions.
  • Added support for color and white temperature UI features in Indigo.
  • Added Toggle Debugging menu item in Hue Lights plugin menu.
  • Changed Hue Lights to now require Indigo 7 or later.
  • Changed LightStrip Plus handling so it appears with the original Hue LigthStrip model in Edit Device Settings dialog.
  • Updated Hue Group device name to show that it's no longer experimental.
Sun Nov 13, 2016 4:51 am
nsheldon offline
Version 1.4.1 Posted
  • Fixed a bug with LivingColors light update processing that caused the plugin to crash.
Sun Nov 13, 2016 12:45 pm
nsheldon offline
Version 1.4.2 Posted
  • Fixed a bug with Ambiance Lights selection list in Edit Device Settings dialog that caused them to not appear.
Sun Nov 13, 2016 1:09 pm
nsheldon offline
Version 1.4.3 Posted
  • Fixed a bug with Ambiance Lights Edit Device Settings dialog that wouldn't allow you to save changes.
Sun Nov 13, 2016 1:33 pm
nsheldon offline
Version 1.4.4 Posted
  • Fixed another bug with Ambiance Lights Edit Device Settings dialog that would incorrectly show an error that the device wasn't an Ambiance Light.
Sun Nov 20, 2016 2:29 pm
nsheldon offline
Version 1.4.5 Posted
  • Added automatic detection and loading of new lights and groups. No need to manually reload lights with the Reload Hue Device List menu item.
  • Fixed a bug that incorrectly reported some updated devices as being out of date (from an old Hue Lights plugin version).
  • Improved hue device status updating efficiency to reduce the number of Hue hub queries.
Thu Dec 01, 2016 3:59 am
nsheldon offline
Version 1.4.6 Posted
  • Fixed a bug that would cause the plugin to crash when updating Ambiance light white levels.
  • Fixed the device startup bug that warned of old devices. The plugin now automatically detects and updates any old Hue Lights devices and simply puts a notice of this in the Indigo log.
  • Changed light and group status update process to use less CPU in mid to large Hue installations.
  • Fixed a potential bug in the startup code that may have caused an infinite device reload loop, and thus high CPU load.
  • Fixed a bug that caused an error when attempting to edit Hue Groups device settings in the Indigo UI.
  • Added some underlying code needed to support scenes and sensors, as well as other Hue features. Scenes and sensors are not yet supported, but it will now be easier to provide limited support in the future.
Sun Dec 04, 2016 1:57 pm
nsheldon offline
Version 1.4.7 Posted
  • Added all Hue Beyond, Entity, Impulse, and Phoenix lights to the appropriate compatable device lists.
  • Added a new Ambiance Ceiling model to the compatible device list.
  • Moved some Hue Phoenix models out of the LivingWhites and into the Ambiance compatible device list. This will require you to re-define or delete and re-create the Phoenix device in Indigo.
Sat Dec 10, 2016 8:11 pm
nsheldon offline
Version 1.4.8 Posted
  • Fixed a bug that would cause an error when editing the Set Hue/Saturation/Brightness action settings.
  • Fixed definition for one model of LivingColors light that was incorrectly placed in the Extended Color/Ambiance bulb group.
Tue Jan 10, 2017 4:24 am
nsheldon offline
Version 1.4.9 Posted
  • Fixed a bug that didn’t save brightness levels of lights for later recall if using the Turn On built-in Indigo function.
Mon Jan 16, 2017 6:06 pm
nsheldon offline
Version 1.5.0 Posted
  • Added limited Hue Scene support with a Recall Hue Scene action which can activate any scene stored on the Hue hub.
  • Added tool tips to all Hue Lights controlled Indigo UI windows.
  • Fixed automated plugin version checking that wasn’t comparing current and latest versions correctly.
  • Improved Hue Groups device setup dialog so you can see a list of all the lights in the selected group from within the device setup window.
Thu Jan 26, 2017 4:31 am
nsheldon offline
Version 1.5.1 Posted
  • Added a Recall Hue Scene menu item to Plugins -> Hue Lights menu to easily recall a Hue scene from the Indigo GUI without having to create an Action Group or trigger action.
  • Fixed a UI bug in the Recall Hue Scene action settings window that prevented the Lights Affected list from being populated on initial action creation.
Sat Mar 04, 2017 7:30 pm
nsheldon offline
Version 1.5.2 Posted
  • Added support for another Hue White ambiance bulb (BR13 model).
Thu Apr 13, 2017 1:51 am
nsheldon offline
Version 1.5.3 Posted
  • Added support for the Hue color cancle and ambiance candle E14 bulbs.
Page 6 of 13 1 ... 3, 4, 5, 6, 7, 8, 9 ... 13
