NOAA Weather Plus discussions
Thu Apr 30, 2020 1:35 pm
Re: NOAA Weather Plus discussions
Please don't use screen captures for code. Put the code into "Code" blocks. It's in the middle of the green "Selection style" bar above the edit window.
that should be:
theTemperatureV = indigo.variables[1708239780] #MinTemperatureVariable
dev = indigo.devices[23142400] #Weather Plus Station
if dev.states['minTemp2ndNight'].floatValue() < theTemperatureV.floatValue():
    return True
    return False
The "[]" syntax is for elements of a dict, which is what "dev.states" is. Parenthesis are for calling functions. You also need to make sure what you're comparing are real numbers (floats).
Thu Apr 30, 2020 1:38 pm
Heh, I edited my answer at the same time you were posting that. ;)
Thu Apr 30, 2020 1:40 pm
Heh - nobody is going to know what you're talking about because I deleted my post! 8)
Fri May 01, 2020 3:15 pm
Ericbo offline
Thank you, thank you FlyingDiver and will know about capturing the code
Much appreciated! Eric
Fri May 01, 2020 3:33 pm
Ericbo offline
Just tried it FlyingDiver and getting the error "embedded script:'unicode' object has no attribute 'floatValue'.
Is it because the variables are unicode (I am pretty sure theTemperatureV would be, not sure what the state minTem2ndNight extraction format would be) or ... ?
(I tried to google this error but did not get much relevant :(
Thank you for your help and teaching!
ps: just copied and pasted your code without any change ....
    return True
    return False
Fri May 01, 2020 4:07 pm
I may have gotten that syntax wrong. Dave's way would probably have worked;
if float(dev.states['minTemp2ndNight'].value) < float(theTemperatureV.value):
    return True
    return False
Mon May 04, 2020 4:19 pm
Ericbo offline
Thanks a lot FlyDiver, tried, got the same error, adjusted a bit after some reading and got the following without syntax error. Will now confirm if it works as expected :)
Thank you for the help!
if float(dev.states['minTemp2ndNight']) <  theTemperatureV.value:
    return True
    return False
Sun May 10, 2020 8:15 am
Ericbo offline
Wondering if you have experience with Weather Plus not returning the expected forecast temperature...
I am getting an embedded script error when converting the temperature string to float. So i assume it is just not returning the usual temperature.
I will have to test for that in the script (error post, script post). Thank you for your inputs :)
Note: I am testing all the forecasted temperature to see if the temperature is dropping ...
May 10, 2020 at 4:05:52 AM
Trigger Weather MinTemperature Change Update (Tonight)
Trigger Weather MinTemperature Change Update (TomorrowNight)
Trigger Weather MinTemperature Change Update (2ndNight)
Trigger Weather MinTemperature Change Update (3rdNight)
Trigger Weather MinTemperature Change Update (4thNight)
Trigger Weather MinTemperature Change Update (5thNight)
Script Error embedded script: could not convert string to float:
embedded script, line 3, at top level
ValueError: could not convert string to float:
Error failed to evaluate embedded script conditonal
if float(dev.states['minTemp6thNight']) < theTemperatureV.value:
return True
return False
Sun May 10, 2020 8:19 am
What are the actual states of the device when you get the error? You can show them in the Indigo UI by dragging the dimple up.
Screen Shot 2020-05-10 at 10.17.46 AM.png (80.22 KiB) Viewed 3836 times
Sat Jan 23, 2021 8:28 pm
indigobo offline
I'm now getting these error messages too :(
Unknown error getting weather for coordinates 36.149, -78.198: <urlopen error [SSL: TLSV1_ALERT_PROTOCOL_VERSION]
Sat Jan 23, 2021 9:07 pm
Are you on an older OS (pre-High Sierra) as well? If so, that's expected. Now.
Sun Jan 24, 2021 6:30 am
Wed Jan 27, 2021 12:55 pm
dherren offline
I started getting these error messages late in the day on Jan. 21st. While I am running on Sierra and not High Sierra, I find it curious that the same version of the plug-in on the same Mac mini had been running just fine until Jan 21, and no changes were made to any of my configuration.
Update: I just read the thread regarding OS level support for TSL and NOW. I get it. I had dreaded an OS upgrade on my late 2012 mini, but the writing is on the wall.
Wed Jan 27, 2021 1:01 pm
The change was made server-side (at NOAA) to require the newer version of SSL/TLS. This is totally the expected behavior.
