Announcer: Spoken Text with Fanfare Audio
Mon Jul 02, 2012 6:51 pm
nsheldon offline
Announcer v1.1.7
(FREE Indigo Pro 5, 6 and 7 Plugin)
Download version 1.1.7 here
Announcer, using the built-in text-to-speech functions in Mac OS X and the background audio file playback features of the Play Sound application (separate download required), plays just about any audio file, followed by whatever text you've entered into the Indigo Pro variable your Announcer plugin devices are monitoring for changes. Each Announcer device and action has the following settings:
  • Pre-Speech Audio File (optional): Any QuickTime compatible audio file. This file will play in the background before (or at the same time as) the text-to-speech voice begins speaking.
  • Announcement Volume: Specify a volume for the audio file.
  • Speech Volume: Specify a separate volume for the spoken message.
  • Speech Delay: Set a delay of between 0 and 10 seconds before speaking the message.
  • Speech Rate: How fast the message should be spoken (in words-per-minute).
  • Message to Say (actions only): Text to be read when the action is executed.
  • Speech Message Variable: An Indigo variable whose contents should be read (for actions) or to be monitored for messages to be spoken (devices). When set inside an Announcer device configuration dialog, whenever the selected variable changes, the Announcer device will speak the contents of the variable.
  • Voice: An available text-to-speech voice to use when speaking messages. (Only installed voices are listed. You can add more through the Speech pane of System Preferences).
  • Optionally, you can specify a specific copy of Play Sound to use. This can be useful if you've changed the name of the application, or if you have multiple copies of Play Sound on your server that you're using to send to different speakers (using Rogue Amoeba's Airfoil, for instance).
Installation
Use the download link above to download the latest version of the plugin. Once downloaded, it should automatically unzip, but if it doesn't, double-click the zip file to decompress it. If you downloaded the plugin from a computer other than your Indigo server computer, move the plugin file to any location on your Indigo server. Once decompressed and moved to the computer with the Indigo server running, double-click the "Announcer.indigoPlugin" icon. You should be prompted to install and configure the plugin. The only global plugin configuration is the option to turn debug logging on or off (it's off by default). Simply click "Save" to continue. The plugin is installed.
Using It
There are two ways to use Announcer. The first, and probably most intuitive way, is to use it like any other action plugin. When specifying an action to take within a Trigger, Schedule, or Action Group dialog, select "Plugin" as the action Type, then select "Announcer" as the Plugin. For the specific plugin Action, select "Announce a Message" then click the "Edit Action Settings" button to specify the settings described above. Instructions are provided within the "Configure Announce a Message" dialog that appears.
The second way to use Announcer is by creating individual Announcer devices. You could think of this as a quick way to create both a trigger and an action by just creating a new Announcer device. When used as a device, each Announcer device will monitor an Indigo variable that you specify for changes. Whenever that variable changes, all Announcer devices monitoring it will read the contents of that variable using their individual settings. To use the device method, within the Devices section of the Indigo client, click the "New..." button. Name the device (perhaps "Message Announcer"). Select "Plugin" as the device Type. Select "Announcer" as the Plugin. Select "Announcer" as the Model. A configuration dialog will appear. All the parameters described above will appear in the dialog (except for the "Message to Say" field). Instructions appear within the configuration dialog box and provide details about what values to enter for each field.
Version 1.1.7 fixes a bug that would cause the Announcer plugin to crash when trying to create an Announce Now action with the Play Sound application not installed and updates the plugin update check code to correctly compare version numbers with more than 2 components.
Version 1.1.6 added optional automatic version checking (enabled by default) and email notifications (configurable in the plugin configuration window).
Version 1.1.5 fixed a bug that caused Announcer to crash when changing the value of an Indigo variable monitored by an Announcer device.
Version 1.1.4 added Indigo 6 UI support and added an "Announce Now..." plugin menu item to immediately create an audio announcement.
Version 1.1.3 added additional error checking for greater scripting ease and added an option to use the default system voice.
Version 1.1.2 modified the voice list code so 3rd party voices would show up properly.
Version 1.1.1 fixes a bug that would cause text taken from a variable with the Announce a Message action to not play properly.
Tue Jul 03, 2012 8:26 am
Re: Announcer: Spoken Text with Fanfare Audio
Cool - thanks for the plugin.
Tue Jul 03, 2012 9:40 am
nsheldon offline
This one was a bit of a learning experience. :-)
Wed Jul 04, 2012 2:07 am
nsheldon offline
Version 1.1 released (yes, already)
Adds an "Announce a Message" action that can be used in any Indigo Actions tab or Action Group. This is probably a more intuitive way of using the plugin.
Fri Jul 06, 2012 8:22 pm
nsheldon offline
Version 1.1.1 Released.
This version fixes a bug that would cause text taken from a variable with the Announce a Message action to not play properly.
Mon Sep 03, 2012 10:44 pm
nsheldon offline
Version 1.1.3 Released.
This version adds additional error checking for greater scripting ease and adds an option to use the default system voice.
Wed Nov 14, 2012 2:50 am
nsheldon offline
Version 1.1.4 Released.
This version adds support for the Indigo 6 UI and adds an "Announce Now..." plugin menu to create immediate announcement messages.
Sat Jul 13, 2013 2:02 pm
nsheldon offline
Version 1.1.5 Released.
This version fixes a bug that caused Announcer to crash when changing the value of an Indigo variable monitored by an Announcer device.
Tue Jul 30, 2013 3:19 pm
nsheldon offline
Version 1.1.6 Released.
This version adds optional automatic version checking (enabled by default) and email notification (configurable in the plugin configuration window).
Sun Apr 30, 2017 10:05 pm
nsheldon offline
Version 1.1.7 Released.
  • Fixed a bug that would cause the Announcer plugin to crash when trying to create an Announce Now action with the Play Sound application not installed.
  • Updated the plugin update check code to correctly compare version numbers with more than 2 components.
